Questions on my new to me '15 Tahoe PPV
6point2lovelifers
Hello everyone!
I have taken possession of a 2015 Tahoe PPV from my local sheriff's office. Just a few questions I got.
First off it has the little 2in black and white instrument cluster, and for whatever reason the sheriffs office put a leather LT kind of model steering wheel. They did a lot of other higher trim conversion stuff like fog lights, chrome grill mirrors, etc. No clue why but I'm not complaining. This steering wheel has controls on it but nothing but the cruise control controls work. From what I read on here, the steering wheel controls go to the cluster. So if they swapped the steering wheel, they would have also had to swap the cluster to get the controls to work. Does anyone here have experience of just bypassing that and easily running the new steering wheel to the radio or you must change the cluster? Note, there is also an aftermarket pioneer stereo with an axxess personalization interface. This had to be an admin car, even the whole interior is cloth and carpet, and is in civilian like condition.
The horn, it also does not work. I wanted to know if there is an easy way to trace this, maybe someone here has experience before I go face first in myself. Of course I checked the obvious like relays and fuses, and as per usual it's never as easy as that. It has a viper car alarm as well so I'm not able to sound the horn and test it that way, but I don't hear the relay clicking when I press the horn from the interior.
The AC is super funky on the truck too. Pressure reading fluctuates depending on if you have rear AC on or off, from around 50psi when rear ac off to 60 psi when on. It blows ice ice cold to where you have to lower it in the front and back, but then suddenly just like a fan blows and then a minute later it'll come back on. Low RPM I notice sometimes it likes to go warmer the AC. Worth noting, pressure goes up when giving throttle. The ac also takes about 3-5 minutes on cold startup and a lot of tinkering to get working. You have to shut the truck, turn it on, turn off the air, turn it on, etc. Does anyone have any clue of what this can be?
Also, I read a lot about the AFM and transmission on these trucks. Should I do the thermostat bypass on the transmission? It has 50k on a new transmission from Chevy and it's due for its next fluid change. My current transmission temp is clockwork at 192f never fails. And the afm, I did a 0w20 oil change with original oil and filter. Did I do good or bad? I read people like doing 5w30 for the lifters but I want to hear another opinion on what you think. And should I get a range technology afm disabler? I know it's not a true delete, far from it, but would it buy me some more time before the typical lifters go? Or will it do nothing and I just have to continue doing 3-5k mile oil changes?
Hopefully someone will be able to answer some of my questions. I really like the truck so far, just has these quirks. The truck confuses me, as I said earlier this must have been an admin truck to be all modified. Viper car alarm, aftermarket radio, side exhaust, chrome mirrors and ltz grill, etc. The interior is also all normal all cloth seating, carpet floors, working rear doors, civilian console, etc. Maybe someone on here has also found an interesting find like this. This was probably some deputies prized possession LOL. Yes this was directly from the sheriff's office I bought this, no dealer, no second owner, nothing. Thanks in advance everyone!
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
I cannot personally assist you with your issues, but other members of this Forum much more knowledgeable than me in the PPV World will chime in.
6point2lovelifers
Thanks for the welcome! I hear a lot of good about this forum, which is why I resulted to here. Forgot an image so here it is, sorry it isn't the best!
Horn wire is probably cut
the steering wheel probably needs the correct clockspring to get the other controls to operate
a basic canned tuner will turn off afm and unlock the limiter, etc
the transmission thermostat can be bypassed with a $20 part and that should drop it down to around 145-160
6point2lovelifers
I agree tune is probably the best option, but I'm not looking to mess with that yet. Just want something basic that would disable AFM and work, until maybe I get a tune one day. It's my daily hauler, not a race truck lol.
Horn wire is probably cut like you said, just wanted to know if someone had a similar experience on a PPV where it can possibly be cut. For all I know that horn wire can be cut all the way on the passenger side of the truck well behind the dash and I can't get to it.
Deff going to do a trans fluid change and get that bypass done, because I noticed my first little slip. I also felt a slight shudder a couple days ago. I had the truck for probably a month or two now so not terrible, hopefully the bypass and fluid would help. Fluid is only 50k miles old but these 6L80's I read need 30-40k fluid changes. I'm hoping the fluid just degraded and that's it. It's a new transmission from chevy 50k miles ago, would be very surprised if it's on its way out but maybe I shouldn't be surprised. I'm going to try to take care of it the best I can. I never get on the truck anyways, it's always low load low RPM driving.
The steering wheel controls I really don't care about at all, I can reach over to change the volume not an issue. If you have to change the clockspring I'll just let it be for now. However I do hear a like bell noise when the steering wheel is locked. If the truck is off and the wheel is locked, and you tap the wheel, it makes a metallic bell kind of sound. I have no clue what it is, maybe it's the clock spring.
First, there is no set 'civilianize' procedure for all PPVs being released to the public. Whatever company is tasked with the process in each town/county will use its own process, and they are not particularly careful or tidy in their work. So, most folks purchasing a PPV go through what you are going through now. If you are not staring at tangled messes of cut wires, you are lucky. You will need to do a lot of wire tracing, to get your truck's features to a place where you want them to be. That's life for the PPV owner, and most of these folks are happy with the results that they achieve.
Second, don't equate/confuse a 'tune' with racing, as that is not what we are talking about. The tune that we are talking about is a process of making adjustments to the engine and transmission control systems that actual increase the life of these components, particularly the 6L80 transmission. Certainly, whether or not to get tune is your choice, but be sure to make an informed choice on this topic.
Marky Dissod
Just want something basic that would disable AFM and work, until maybe I get a tune one day. It's my daily hauler, not a race truck.
A proper & thorough tune can make your Tahoe a better hypermile-mobile, or tow pig, or whatever suits you.
You ought to speak with enough well-reviewed tuners until they shatter this unfortunate stereotype.
Also you'd know that a tune may very well delay/mitigate the next rebuild of your 6L80E.
In other words, go learn more about what a good investment a PERSONALIZED tune is (not a plug-in tune, or a canned tune).
Don't poo on this option:
he's sort of like a tuner, butt he only enables & disables bug-features by flipping simple switches.
He doesn't actually tune (or delete) anything by messing with constants or tables.
the price you pay for the little obd dongle to disable afm and has to stay plugged in is only marginally cheaper than a canned tuner device, that can turn afm off, adjust your shift points, adjust the tire size and misc other things such as the parked rev limiter and top speed limiter.
the little "ding" noise you hear could be anything the k2's have a ghost in the machine, the simple act of opening a door wakes the truck up from a deep sleep
6point2lovelifers
Yeah unfortunately I am like most, taking off the kick panel reveals a whole bunch of wiring that makes no sense. Gonna have to nose dive into that. I hope the results in the end are worth it though! Loving the truck so far.
Also, thank you to everyone's input on tuning. You guys really made me reconsider, and I will probably get it tuned. I want the truck to last me for a little while, so tuning is probably going to be the best route. Again, thank you for all the advice! I'm new to all of this Tahoe stuff, especially from this generation. The only other Tahoe I owned was a 2009 PPV which was a tank. The best truck I ever owned! I don't expect this one to go even near with reliability.
JoeBlobs
Senior Member
NJ
@6point2lovelifers
I'm not too familiar with your generation but for the GMT900s there is a super helpful upfitter guide that shows you where the wiring harnesses are for things like spot light, headlight flashers, rear speaker bypass, horn wiring, ect. Upfitters will intercept the horn signal and adapt it to control the siren in various ways. In the 900s the wiring harness for the horn is labeled with an RPO code behind the center console, as well as other harnesses. Perhaps yours is the same.
For the horn wiring sometimes we would grab it from the BCM, sometimes the steering column. You can start your search there. Use this website to find pinouts and wiring diagrams.
With a quick google search I was able to find similar documentation for your generation. Maybe what you need is here, but it would also be good to just read it over.
6point2lovelifers
@6point2lovelifers
That is all over and beyond helpful, thank you a lot for your help!
alexblagoev
