Suburban died and won't restart (but sometimes it does...)
project_x
I was packing up to head to the cottage... And my Suburban started and died as I was reversing.
No Codes
Just cranks....
My feeling was the fuel pump...
When I go home from the cottage (it sat for 3 days), I pulled the fuse (good) and reseated it and swapped the fuel pump relay with the horn (horn still works). It started right up.
No visible fuel leaks, drove it around the driveway, start every time no issues, still no codes.
After trying around my property for a a few days, I decided to go to the lumber yard and a couple of stores close to home.
No issues, until the very last stop. (Stopped and started many times, no problems). When i tried to start it at my last stop... it would crank, run for 2 seconds and stop. No codes
Waited 30 min for a tow truck, tow truck driver starts it and drives it on to the flatbed.... and then drove it off at my house.
I try to move it to a better spot and it stops...
Yesterday, I put a fuel pressure gauge on it... says 60psi and it ran no issue for 45 min in my driveway and was able to move it no problems....
Ideas?
Crankshaft position sensor?
TJ Baker
Colorado
Ideas?
NO!! Replacing a CKP requires a relearn and that requires a $$$ scantool. I would never replace a CKP unless it was conclusively proven bad.
Most likely an intermittent electrical issue.
When it fails to start, what is seen at the instrument cluster? Security light on ?
mikez71
Bad fuel pump or CKP are prime suspects for an engine dying, without codes or other symptoms.
You may have to wait for it to happen again to check the fuel pressure..
Moderator
People's Republic of Colorado
I would suggest monitoring the intake air temp and the ambient air temp to see if they are accurate.
Also, have you tried clear flood mode after it happens? (Hold accel pedal to the floor while cranking.)
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Next time it happens smack the bottom of the fuel tank with your fist or something and see if that wakes up the pump. Then you'll know.
Moderator
When it doesn't start, have someone turn the key on while you listen by the fuel tank to hear the pump running. If it doesn't, try smacking the bottom of the tank.
Moderator
Smack that asss
That's how I got mine started on the last morning of a camping trip a few years ago. Stuck in Laramie, WY, at a campground waiting for the tow truck. Wasn't sure what I would do with the camping trailer while the Hoe got fixed. But I whacked the tank a few times and it started right up. I didn't turn it off until I got home later that day, and installed a new pump a few weeks later.
LsHart
Senior Member
In this situation I would blame the fuel pump. The ohms are climbing and it shuts off til cool. Also, am I missing something? Don't see the "what are we working on" part.
LsHart
Senior Member
Okay, what was the readings? I guess its fixed Fless?
LsHart
Senior Member
Whats koeo? And after 5 minutes holding that pressure, does it drop?
P
project_x
Engine running 60psi
Koeo 60psi
It did not drop after 5
LsHart
Senior Member
Well, if it's not acting up then that's a good thing.
Candielaine
