I was packing up to head to the cottage... And my Suburban started and died as I was reversing.
No Codes
Just cranks....
My feeling was the fuel pump...
When I go home from the cottage (it sat for 3 days), I pulled the fuse (good) and reseated it and swapped the fuel pump relay with the horn (horn still works). It started right up.
No visible fuel leaks, drove it around the driveway, start every time no issues, still no codes.
After trying around my property for a a few days, I decided to go to the lumber yard and a couple of stores close to home.
No issues, until the very last stop. (Stopped and started many times, no problems). When i tried to start it at my last stop... it would crank, run for 2 seconds and stop. No codes
Waited 30 min for a tow truck, tow truck driver starts it and drives it on to the flatbed.... and then drove it off at my house.
I try to move it to a better spot and it stops...
Yesterday, I put a fuel pressure gauge on it... says 60psi and it ran no issue for 45 min in my driveway and was able to move it no problems....
Ideas?
Crankshaft position sensor?
No Codes
Just cranks....
Ideas?
