Lost my speakers
Jdsfx1
This is a weird one, I lost my front and rear speakers. The sub still works and the tweeters work, but all others went silent. It’s a factory Bose setup with a new Boss head unit. I’m thinking it has to be within the Bose amp or ???
First, I'd pull the head unit and check to ensure that all connectors are fully inserted in place.
J
Jdsfx1
Verified head unit connections. What’s mystifying me is why the sub and tweeters work.
LsHart
Senior Member
Factory amp and or fuse
LsHart
Senior Member
I think my amp is about to go. Hit bumps and static comes theu the speakers. Or feels like one cuts out.
J
Jdsfx1
Would be nice to have some vehicle info in your signature so we know what you're working on. Year, make, model, engine, etc.
Sorry, 1941 Cadillac…….sitting on an 08 Yukon Denali XL.
J
Jdsfx1
Update……turns out I had bad connections at both front speakers. I cleaned the pins on the speaker and on the connector and it ohm’s out correctly and the front speakers now work fine. Now to figure out why the rear speakers don't work, wouldn’t be surprised if it’s the same issue.
I'm glad to read that your issue is resolved. Please add the word "FIXED" or "SOLVED" to your thread's title, to let others who are experiencing a similar issue know that this thread has an identified solution.
J
Jdsfx1
Thanks for the tip, I’ll add “solved” once I figure out my rear speaker issue.
CWool
