Bronson357
- Joined
- Jul 4, 2025
- Posts
- 142
- Reaction score
- 62
OK so new to me burb i can't get the shifter to m, shifter works fine in every other position. Is there something I'm missing??
Pull it towards you and down?
If you crawl under the car, can you manually shift it to "M"? Don't forget to set the parking brake and chalk the wheels so you don't get run over.Anyone know what I may need to do? It shift fine into all gears except,m ,new shift arm? Seems the cable is correct,since all positions line up. Is there a possibility of a relay or fuse causing this? I definitely feel all detents in the shifter and really no slop.
Any ides and thanks
I was looking at that and didn't think it looked right! Thanks! LOLChock, my friend! Chock!
