3 bolt vs 4 bolt steering box
Multnomah Falls
The pics seem to show a difference in the shaft diameter, where the pitman arm attaches and therefore would not be interchangeable.
S33k3r
Dallas, Texas
Thank you all for you input. My application is a 2005 Tahoe LT 4x4 5.3 with hydro Boost . I have put 5 steering gear boxes in my tahoe ranging from remas to new ones. and even a Red Head box. but they all develop excessive input shaft play. When you look them up on a parts website they ask you if your unit is 3 or 4 bolt. I was wondering if the two were interchangeable?
Do you have a lift on your Tahoe? That's either causing your rig to eat steering boxes or you have a different suspension problem causing the same effect.
91RS
GA
They are not interchangeable. It’s the splines on the shaft not the number of bolts. 4 splines is for a van as far as I know.
houstontaylor
I have a 3 mounting bolt to frame steering gear on my 2003 Tahoe. A shop noticed a hairline crack around part of the the fillet weld on lower bolt tube that runs through the frame and noticed the gear box mount moved some at that point. I had another shop reweld the cracked mounting bolt tube to frame weld. One shop said Chevy went with 4 bolts later to help avoid that problem.
wjburken
Eastern Iowa
I believe the 32 spline (4 locators) is for 1500's and 33 spline (3 locators) is for 2500 and 3500. At least that is what I came across when buying one for my sons 2500HD which took the 33 spline (3 locators).
Instigator01
