Rear Axillary heater core question
Here’s the sawzall method of removing the rear hvac. I’m going to assume the heater hoses he cut are readily available for replacement though.
like how he ends it right there leaving you hanging with those "quick connects" well those are a MAJOR or can be a major pita to remove especially without breaking them which is why he cut the lines to begin with.
all I can add is "good luck with that" if you are lucky you could maybe crush those lines enough to get them out without breaking the plastic
petethepug
Michael
SoCal
That’s good info because you can learn from other peoples mishaps. Thanks for chiming in to advise that what’s most important is what’s been left out.
petethepug
Michael
SoCal
If that’s a shop, I wonder if the customers got their vehicles back with the entire rear hvac removed as the fix and not know it.
petethepug
Michael
SoCal
Well, I did see that there were still some OEM rear carpet kits on the internet if you’re looking for an excuse to pull the rear carpet and replace it. Maybe you’ll find a secret compartment with a treasure map
opfor2
opfor2
Riverside County, CA
My SSV has a rear rubber mat which is still in good condition, so I'll be keeping it. Now to get motivated to do the job lol.
petethepug
Michael
SoCal
I didn’t think a new sub bass would motivate, the carpet, ehh maybe. The panels come out pretty quickly. You’ll need to take off the p/s 2nd row seat belt to allow the plastic to be completely removed.
Trickystick19
