2015 Tahoe Factory Backup Camera Replace With Aftermarket?
Berkdog
I have a 2015 Tahoe LT and 2018 Yukon Denali, and the backup cameras are horrible at night. Can an aftermarket camera connect to the original harness and work with the factory stereo?
Big Mama
Virginia
Welcome to the forum from Virginia. There are lots of plug and play cameras out there where you won’t need to tap into the wiring.
RoadTrip
Saint Paul, MN & Tampa, FL
Part of the “haze” at night is the reflection of the license plate lights off of the reflective plate. Do not upgrade your license lights to LED or the haze will become more pronounced.
Almost makes a guy want to connect the license lights to go off, via relay, when the reverse lights come on…
fatmonk8
Did anyone ever find a good plug and play camera upgrade? I have a 2015 Tahoe a d the camera is pretty terrible.
Big Mama
Virginia
If the OP doesn’t chime in the link above should work well.
Thrust
ICT
I found that bright LED back up lights make a big difference with the camera at night.
the one in my wifes 16 is terrible anytime.......... looks like a kids potatoe cam
so I am also looking for recomendations for a better plug-n-play camera
griffey_mojo
