P0200 came back.
Get that new connector? I was looking at the soldering on that wire and it doesn’t look great IMO. Looks like either the wire was contaminated or not enough heat was applied. I’d get a new connector and make sure to cut some wire off the end of the old stuff so it’s good and clean, solder it good and use heat shrink tubing so it doesn’t corrode. You don’t want that to bite you at a bad time like in the middle of winter.
rick3645
