ColoredPencils
Install looks great! What Dvd unit did you end up using? Are the lights on the unit led? I want one that has lights to match the interior lights.
I went with the 13" Audiovox bc of the internal dvd along with hdmi and usb inputs. It will allow to me use my Roku stick which is a plus.
The lights are LED and the temp matches the factory LEDs. The output pattern is a little different because each dome has three LEDs and a plastic shroud. Still better than a bulb.
Cha0s13
Oh wow I like that one a lot. whats the model# I may order that one. Hows the view through the rear mirror when its down, does it completely block your view?
ColoredPencils
Scratch that. I noticed the lighting tonight and it's more blue than the factory LEDs.
It blocks the rear view mirror pretty much completely.
Model is avxmtg13uhd. They make a 10" model too but I think it would block most of the rear view as well.
Kpwweb
The factory unit blocks about all the rear view as well...
Gissel
Looks great! Where did you get the fogs from? Did you install them yourself?
Got them on protuninglab.com easy install! Slightest mission was deciding were to put the switch to turn them on since we decided to not have them turn on with the day time running lights
Angel87
Where did you end up putting the switch?
anasmak11
Thanks, yes changed all shocks to the Bilsteins. It raised the front and made the ride MUCH better, the car stopped bouncing around and is a lot more composed.
I would say this is a must mod for this car.
Weber Dude
Washed/detailed it. It's been a couple weeks since the last wash/detail. I usually do this once a week.
Kpwweb
Dropped the rear 2" (really closer to 1-1/2"). Now it sits about level--with all my stuff it sits 1/2" down in back. Need to drop the front today!
chicagofan00
Arizona
Put a new grill on the Tahoe today. Took about 2.5hrs from start to finish but only due to a few stubborn plastic tabs that I thought needed to be removed but actually didn't. Wasted about 30 minutes on those suckers....
Now just need to get rid of the rest of the chrome.
ASG-MikeS
