Steering Shift and Pop
Graystone_OG
NYC
So my truck has this weird issue and I don't know what else to try or check. Whenever I make a full lock, I feel the steering shift past the turning radius, make a popping sound and the tires squeal.
I replaced everything I could like the upper control arms, lower ball joints, steering rack and tie rods, wheel bearings and still does that weird pop. Don't know what else to replace or know what it could be. Next thing I'm leaning to are the axles since it's 4wd, but I wouldn't think they could cause the truck to shift like that.
What do you guys think it could be?
Have an 07 Tahoe LTZ.
Sent from my Nexus 6P using Tapatalk
Graystone_OG
Graystone_OG
NYC
Wow nothing. My problem is that unique.
denalianyone
NYBlackLade08
New York
Maybe something can be loose and/or not torqued properly. Check the sway bar linkages
Graystone_OG
Graystone_OG
NYC
It's a total mystery. After i replaced the steering rack and tie rods, I had got an alignment too. I had actually replaced the swaybar links and bushings with Moog beforehand.
08grey
See if the spindle is hitting the control arm.
drakon543
It would actually be possible for the front cv shaft to be causing some issues if they are binding. At full lock is when your putting the most strain on them even with the 4wd disengaged. But i haven't worked on one of those models yet but i did have a similar issue with a 94 f150 i used to have. The univerals were so dry they were binding any time i tried to make a turn.
Graystone_OG
Graystone_OG
NYC
That's sound about right. Now that I think about it, it would sometimes make the pop if I reversed after doing a full turn. As if the axle was popping back in place. I was inspecting the problem before and they did have a weird angle to them when I was looking for the problem.
drakon543
You might be able to duplicate the sound and give you the chance to watch it if you lift the front up in the air and have someone turn the wheel to lock and hold it while you try to spin the tire.
Graystone_OG
Graystone_OG
NYC
Good idea. I just wish I had started there and not replace everything else involving steering. I was so confident before that it was the steering rack, cause the rack had a lot of movement when turning the wheel side to side. Kicked myself in the ass when the problem was still there.
drakon543
Honestly it's probably a good thing you went all out if you already noticed anything loose in the steering it would have continuously got worse and you would have had other issues.
black pearl
NC
my old one did that back in the 90's and i had bumped the push button 4wheel drive. make sure you are not in 4wd
Graystone_OG
Graystone_OG
NYC
That's true. The front end does feel solid now. Ordering the axles soon, then I finally get peace of mind.
Graystone_OG
Graystone_OG
NYC
I actually forgot it in 4wd once after it had snowed, but didn't stay like this long. It's also harder for it go in 4wd, since it's a big knob that has to be turned.
drakon543
Peace of mind is a light way to put it. You DONT want one of those shafts breaking while its under motion.
Slow5.0
Missouri
I had same issue if going in reverse out of my driveway and steeting all the way to the left. It turns out to be upper ball joint. If you get new upper control arm from Autozone it will last only 2 years lol
Graystone_OG
Graystone_OG
NYC
I had thought the same with the ball joints, but I replaced everything and still had the pop. I installed Moog arms, so I'm good lol.
HeavyHoe03
