Illuminated Door Sills
chicagofan00
Arizona
Has anyone done this install on their Tahoe yet? Was looking at getting a pair for the front doors but wasn't sure of the install difficulty. Dealership wants $450 for parts & installation but I can get the parts off eBay for $250 and willing to do the install myself provided it is fairly easy.
Cha0s13
Im also interested in doing this mod on my 16' Tahoe.
chicagofan00
chicagofan00
Arizona
I contacted one of the dealers selling on eBay and asked for installation instructions. They said they would email them over but so far nothing...
chicagofan00
chicagofan00
Arizona
Received the following instructions. A bit more involved than I had originally thought...
1.Remove the left and right front side door sill garnish moldings. Refer to Vehicle Service Manual.
2.Remove the left rear side door sill garnish molding. Refer to Vehicle Service Manual.
3.Remove the left center pillar lower trim panel. Refer to Vehicle Service Manual.
4.Remove the left front floor console extension panel, if equipped. Refer to Vehicle Service Manual.
5.Remove the instrument panel knee bolster. Refer to Vehicle Service Manual.
6.Remove the instrument panel insulator. Refer to Vehicle Service Manual.
download
7.Remove the left center pillar ground screw (1).
Caution: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
8.Attach accessory harness ground eyelet (2) to the left center pillar and secure with the ground screw.
Tighten
Tighten the ground screw to 25 N.m (18 lb ft)
download
9.Rout the accessory harness (1) through the harness sill and sheet metal.
Tie wrap accessory harness to body harness at sill branch.
10.Continue to route accessory harness on top of body harness to I/P harness above the park brake mechanism (2).
Tie strap accessory harness to the left cowl at the low and high side.
download
11.Route accessory harness wire up to the BCM.
12.Remove the GRAY BCM connector 7 (1).
download
13.Remove circuit #157 (GRAY) from cavity 1 and cut off the terminal.
14.Strip the cut wire and insert into the PINK splice sleeve on the accessory harness.
15.Crimp the wire in the PINK splice sleeve and heat both ends of splice with heat gun.
16.Insert GRAY circuit into cavity 1 and reconnect to the BCM.
download
Note: GMC vehicles have console, Chevrolet does not. Harness routing works on both vehicles.
17.Continue to route accessory harness (1) along the HVAC duct on the driver’s side of the I/P, (a typical service routing).
18.Cross the center of the vehicle forward of the steel I/P to floor console brace, use three 12” tie straps or doubled up 8” tie straps on the left, center and right side of the HVAC duct.
19.Tie strap the accessory harness to the body harness forward of the sill trough.
download
20.Connect the front side door sill trim plate harness connector (1) to the power supply connector (2) into the new front side door sill trim plates (3). Do not fully install the sill trim plates yet.
21.Move the sill plates away from the door opening. Close the doors to reset the lighting time out. Open the doors and confirm the illuminated sill plates are functioning.
22.Confirm that all wire routing are hidden. Secure all tie straps and cut off the tails.
23.Re-assemble all removed trim components to vehicle.
24.Verify that no wiring is visible or interfering with anything.
25.A total of seven areas will have wiring tie strapped into position.
Front of each sill plate; Qty: 2
High on the left side of cowl; Qty: 1
Left, center and right on driver’s HVAC duct; Qty: 3 – 12” straps
Right edge of the floor console, if equipped; Qty: 1
Ridechevy09
South carolina
download
Tighten
download
download
download
download
download
I wish tapatalk would work. I can't see the pictures
Sent from my SM-S978L using Tapatalk
chicagofan00
chicagofan00
Arizona
Might not be a tapatalk issue as I couldn't see the photos in Safari on my iPhone but I can see them in Safari on my iMac. In any regard, here are the photos by themselves just in case.
SkierMan
Anyone successfully removed the pin? or are most people tapping the wire with a posi or t tap and leaving the pink connector? I can't figure how to remove the pin from the molex connector.
SkierMan
Was able to get the pin out, but not easily as someone knowing what to do would. Used enough force that I got worried.
K2 Kaiju
The Depths
Bump - these are around 50 bones on ebay right now but I didn't get instructions. They look factory - crazy good deal...
K2 Kaiju
The Depths
I watched this vid - starts about 15:20 for our style connector. Just put mine in - factory connectors and much nicer than scuffed plates in there...
JasonW4141
