want the rear 1" lower after belltech's
squigmang
Hey all,
I've installed the Belltech 34324 rear lowering kit with the 5305 springs.
I would like to get it about 1" lower.
Is there any way I can achieve this?
S
squigmang
I messaged him before I started this thread because he seems to be the go to guy, but he wouldn't help because I did not purchase from him.
Anyone know if it is possible to get lower with these springs, if I shorten the autoride rod a quarter or half inch more will that help or cause problems?
NathanJax
Vacation Nathan
Jax, Fl
Could cause problems and won't help going down an inch because the weight will be on the springs instead of the springs and shocks.
I'm sure he would help you by buying new springs.
Only option WITH those springs is to cut them, which I would NOT recommend.
(not trying to be mean, just speaking the truth)
S
squigmang
I didn't take it as mean and I appericiate the truth. That's what I'm here looking for.
I wouldn't cut the springs. I'll learn to live with it or get new springs. Thanks for the help.
NORCAL SS
SUV SUSPENSION GURU
Hey all,
is this a autoride truck? Just saw its a autoride truck
are you using spacers in rear?
did you cut bracket off frame?
how is front lowered?
What does the truck measure from ground to fendelrip all around?
NORCAL SS
SUV SUSPENSION GURU
also what does your trukc measure ground to fenderlip all around?
Smoke
Find that hard to believe, he worked with me before, during and after my purchase. If you haven't dealt with Tony your missing out...stand up guy. When he says 24/7 it's backed up
briannorris
