Post your lifts.
Lenny84
I'm sure this has been asked , but i wanna run 33/12.5/15 , right now I'm at stock hight, will i be able to run that wheel and tire combo with a leveling kit. if not how much of a life do i need to not be rubbing. i don't want a lot of wheel well space . i want minimal lift to fit the wheel and tire combo. thanks y'all !
ATIII
Brighton, CO (Denver)
Feelin' good about myself today. Got her all shined up today and saw a stock twin for a photo opp.
Flexx
You did a body lift right?
Sent from my HTC One M9 using Tapatalk
Flexx
Nope, keys Z71 springs and 2" spacers
What's your ground to fender measurement? Looks huge.
Flexx
39 3/4 - front, 40.5 - rear
Thanks.You're an 2 inches higher than me all the way around. I did 1" rear and 2.5" front. Going to crank the front to dead level this week before I do alignment though. I'll be at 38.5" all the way around.
xFuZzYx
IASCA Car Audio World Champion
What a badass rig! Hopefully mine will look like that by this time next year. Is that the NTD RC KIT?
Yes it is, I had to cut like 2-3" off of the bottom corner of the front bumper but im still rubbing pretty badly on the back corner of my fender well, I'm about to replace my stock torsion keys with 3" ford torsion keys to raise my front end up from 7" to 8.5"/9" so I can fully turn my wheel again and completely clear my wide ass tires but I will have to remove my CV axles because of the extreme angle the new keys will put them at. But at the same time now I wont have to ever worry about them binding up on me and causing something horrible to happen like causing my hub to break... Plus I never go off roading in my truck, I mean I have 5 tv's and a world title winning sound system in there and there is no way I would ever risk doing something that could mess any of that up so its not like i ever used 4wd anyways lol.
01Konvict
Boats n Hoes
Raleigh/SML
Uh wow! :chair: Take cv out cause of angle?! That is asinine! Get lift keys and a 1.5" body lift then NorCal mod the rear fender side.
Duramax05blk
NH
Removing cv will cause a wheel hub failure. Bearing will explode
Sent from my SM-G900V using Tapatalk
xFuZzYx
That is what a rough country rep said to me on their tech support chat on their website... I also thought the cv axles would still be fine at a slightly increased angle but according to their representative removing them is what they "strongly" recommended. Go figure lol...
Ive never heard that before, are you serious? I know quite a few people who had 4wd round body and cat eye trucks/tahoes and removed their cv axles without any problems...
Duramax05blk
NH
Yes I'm positive it does on 2500hds. And use same hubs basically. you could cut axle and just have the inside and nut to preload bearing. If when it does happen you loose the wheel as well.
xFuZzYx
so what do you think would be the best thing for me to do as far as my cv axles go then? just leve them in, remove them completely, or something inbetween the two?
Duramax05blk
NH
I would leave them in or have the cv cut so only the threaded shaft and machined service behind knuckle was left.
But if angles are really that bad that you can't turn in 2wd on street its probably better to just get a bigger lift or less wheel
xFuZzYx
its rubbing because of the -76 offset, not because the tires are 35's, and once I get the 2 more inches of lift from the bigger keys ill be able to fully clear my wheels without catching anywhere.
01Konvict
Boats n Hoes
Raleigh/SML
Like I said the lift will take lift keys but don't crank them to max and get some cognito UCAs. Pick up the zone 1.5" BL for trucks and norcal fender mod if needed after all that work. If you take out CVs the hub will grenade! You have to run 2wd stud nubs to keep it together but still leave the damn 4wd.
Conedaddy
