Looking to put 2015 seats into my 2008, anyone know if they'll fit?
eagle-co94
Hollywood, FL
I just picked up a 2008 PPV that's missing a rear seat and I have a line on a 2015 rear seat fresh out of a new PPV. I won't have the chance until next week to drive 2hrs for a test fit. Anyone know if the seats will bolt in or if the mounts were moved? My ultimate goal would be to get matching front seats as well if they do.
Any input would be great. I just don't want to waste my time if someone out there has already tried to upgrade.
eagle-co94
eagle-co94
Hollywood, FL
If I get access to some 2015 rear seats I'll let you know. I can't get a straight answer and a local seller off ebay wants me to make an offer before I meet up to test fit.
CrashTestDummy
Pearland, Texas
Well, similar component part numbers between a 2011, and a 2015 are different. That doesn't necessarily mean they won't work, but it does add a level of complexity to the mix.
OneTwo
Vancouver, WA
I can almost guarantee you that they won't drop into place and bolt right up like they're meant to be there, however they may be close enough that some minor modification is all that's needed.
However, I'm assuming that 2015 means the newest and current body style Tahoe. If they ran some PPVs as 2015s but they are still '07-'14 GMT-900 body style (it's not like GM hasn't done this before), then the seats should be a direct fit.
eagle-co94
eagle-co94
Hollywood, FL
I've got an update on this. I just picked up a few sets of 2015/2016 rear seats and they do in fact do right into the trick abs bolt right up! Only issue is the seat belt buckle and latch changes slightly going in 2015. The latch is about 1/8" narrower so you'll need to find some belts or replace the latches on the seats. The middle belt is fully integrated though so it works flawlessly.
Having said all that I've got a few extra seats for anyone wanting one.
Dirty 30
Dallas, TX
Is the height and width the same? Can you send some pics of how the 2015 seats look in the 2008? I want to put a bench seat in my 2009 Escalade and was about to remove my 2015 PPV rear seat bench to try it out. Luckily I found this thread haha!
eagle-co94
eagle-co94
Hollywood, FL
Yes the 2015 and up seats bolt in perfectly however the seat belts do not match the outside seat buckles. You'll have to either get new belts or probably grind down the latches so that they mate up with the buckles.
Youngerjc
Thanks i am looking to buy some
Youngerjc
How about harness? On my ltz i have heated and lumbar. On the 2016 seats i am trying to buy has heated cooled and lumbar.
eagle-co94
eagle-co94
Hollywood, FL
No clue as my truck is a PPV so there was nothing to plug in. There may be a harness under the floor but I have no need to look.
sick1166
so I know the backseats bolt in 2016 to my 07 but was that a yes on the front seats as well?
Russman
Old thread, But do these fold flat?
Pictures?
Thanks
Hodmjstone
