How many of you DO NOT experience buffetting and vibration problem?
Hayseed_Yukon
Yes. Same hayseed as bimmerfest. Does the yukon have something like the bmw connected drive where I can do online searches? She never gets motion sickness but the passenger seat in the X5 does it to her. Everyone else is fine.
Cmicasa the Great XvX
Here is my take..
Set-Up is Max Trailering Package, 275/55/20 Continentals, Auto-ride
I went thru the ride issue where I felt a vibration when going above 65 and in some instances.. suspension felt out of whack even at low speeds if hit even the slightest imperfection in the road.. this was AFTER.. I went to the dealer for an Oil Change and Tire Rotation where they also added air to my tires.. 35psi.. which is the recommended. I then commenced in dropping them back to where I was before I took it in.. 33PSI all around and the vehicle rides as smooth as a Caddy now. No vibration, not roughness.
ajs800
Michigan
Here is my take..
so basically, you notice a big difference in ride when tires are 35+psi vs 33psi or less?
Yep. Even my '14 Stingray simply rides better when it is around 33psi. The '14 Impala? Same thing. The '16 CTS-V? Yup.. I think the inflation numbers are because of fuel economy testing or something.. but I have no issue burning an extra gallon of gas if the ride is smoothed out like it tends to be at 32- 33psi.
ml55
Tahoe LT 2015 zero milage (6/2014 Built), The car suffer vibration and i got few times headache and dizzy after driving
Planing to change the tyres ASAP now the challenge which Brand i will chose !!
ajs800
Michigan
If you're not concerned about off road performance, you can't go wrong with Michielin LTX or Michelin premier LTX. I went with the premier making sure all RF balanced under 15lbs and buffeting was 99% fixed. I am sure many tires will be fine but make sure they RF them and they are under 15lbs. Shouldn't have to but these trucks are ultra sensitive.
Yukon John
SE florida
Here is my take..
I have the same set up in my 2016 SLE...including the same wheel/tire combo. Mine is the SLE model with no sun roof. I has a bit of perceptible buffeting at about 50~55 when I am in V4 mode. I have AFM turned off via my Diablo Tune...now it's smooth as silk from 0-125+. I am running 35 PSI all 4...very smooth and quiet.
adventurenali92
Big Bear Lake, ca
I switched from the factory Bridgestone dueler alenzas that were on my 2006 Denali when I bought it to Michelin premier LTX A/T2 and the difference was night and day! Love my Michelin tires.
Yukon John
SE florida
As far as I'm concerned and based on decades of experience...the Michelin LTX A/T2 and it's predecessor the LTX A/T are the best tires on the planet for a SUV or Light truck. I have run several sets of those tires on Tahoe's, GM and Ford 4 x 4 pick ups for over 25 years. They are the best...period !!
adventurenali92
Big Bear Lake, ca
Had them just about a year now. They were take offs with about 1,000 miles on them and got all 4 of them,gone $300! They're holding up quite well!!
JRLittle
2015 yukon slt 28,000 no issue so far however did experience this occasionally when conditions seemed to be just right on older ones I've had.
showtime1k
Is the buffeting related to the ear oressure
Agreed. I lease all my vehicles through my business; does not make sense owning. So I am less concerned than others about first year issues. My infotainment screen is glitchy also and it lurches hard when shifting into drive/reverse when the transmission is cold. They fixed a bad cable in the infotainment console that was causing the screen to go black occasionally.
Besides these issues, and due to the fact that I carry no sentimental value to vehicles due to leasing, I really love this truck!
is the buffeting related to the ear pressure situation. Will the afm disable correct the pressure also
MonteJ
