Fosscore
Swapped the 24s to the 05!! Much better and the Nali wheels don't look too bad in the 03 either.
Before
After
And some extras.
Looking good. Nice switch on the wheels and what a ride to buy!!
Sweet.
Rivieraracing
Finally got around to swapping out my LS1.com fan harness that I had for 7 years to an OEM one I bought off of another member on here in the denali! Took me longer than I thought it would but is usually the case since I over think everything and want to get it all right the first time! Seems to work great so far, nice to finally have the relays next to the fuse box instead of next to the motor and all the heat!
David Paul
Central NJ
Changed the rear differential oil and cleaned/painted the cover. Another good day in the garage. Next up is the front differential and transfer case along with the servo mod....
05Single
afraid of the dark
Before
After
And some extras.
I had to take a double look lol. You made the right switch for sure. Both look top notch
Gzes
the drifting 2dr
Wichita tx
Gave the escalade. Much needed face lift. New fender and pulled on the core support. Gotta finish pulling on the back and I'll be able to slap the tail gate on. Maybe then people won't think it's an avalanche..
Five
North Carolina
Put in the big transmission cooler, changed the tranny filter and made such a huge mess that I quit for the night...I'll wrap it up in the morning.
treehan77
TYF Fiend
Crestview, FL
replaced the two burned out bulbs in my digital ac control. radio shack only had two bulbs. so of course i find out there is actually 4 out inside. i guess i suck at soldering, cause now theres another bulb out that worked when i had it on the bench. oh well, guess i'll do it again when radio shack restocks.
elcapitanmas
just finished chasing down a coolant leak (quick connects at heater core) new powerstop rotor and pad kit front and rear, new master cylinder and a couple front suspension fixes (pittman arm, ball joint, tie rod) not cheap but needed to be done. rides and stops like a dream now
Boxdgm
MN
Did some maintenance and spring cleaning today. Replaced both hubs, pass outer tie rod end and idler arm. Then i cleaned the MAF and throttle body and sucked a can of seafoam through the brake booster vacuum line. Handles much better and runs smoother now.
#1taho
5150TAHO
niagara falls ont
Got may stainless steel brake line kit yesterday and starting to install it today. Looks like a lot of fun
wwiizz
