MrBalll
West Texas
Had quiet the scare yesterday. Replaced the differential fluid last weekend. Did the transmission fluid and filter this weekend and the truck had been sitting for that whole time without being turned on.
So I turned tried to turn it on after the transmission filter and fluid and it didn't even crank. I thought I killed it. But the back half, interior and brake lights worked, but not the front half interior or headlights. Dash lit up, just very lightly. So I plugged in my battery charger and it reported about 8V total charge. So I charged it and it cranked right up.
Going to look for a battery drain this week on my day off. Always had battery problems with this Tahoe, just never had the tools to look into it.
David Paul
Central NJ
Replaced bank 2, sensor 2, O2 sensor to fix MIL. Did the hydro boost flush as posted in the tech section. Flush was very easy, less the 1/2 hour start to finish and really did make a difference. I was pleasently surprised. It was a good day in the garage. Now waiting for efan kit to arrive later this week. I like this site but it's costing me $$$$$.
Gzes
the drifting 2dr
Wichita tx
So looks like rear main seal is leaking.. trying to figure out if it's worth camming and stall tune or just do main seal then exhuast and intake and tune.. not a baller so budget is key. The escalade has a decent bit of get up and go as it sits being awd just kinda want a wee bit more and stay reliable
DarkBlueHoe95
West Columbia, SC
Pics of the truck?
Sent from the USA.
How it sits now.
As the pic above shows I installed a new drivers side torsion bar and installed lift keys cranked up a bit. Also threw on yukon 17s, toyo 35s and some 1/4 inch spacers in the rear. Will be looking into actually spacers soon because of some of the rubbing. Going to have to flip my rear upper shock bolt to prevent rubbing as well.
Before
Almost there
And after
Planning on z71 springs instead of rear spacers.
My Dark Blue Hoe
Five
North Carolina
Ordered a crap load of stuff: keys, bilstein 5100s, z71 coils, bounce stops, TJ sway bar links, 1.5" coil spacers, wheels, tires, etc. Got a lot of work ahead.
Yuko04
"SquareBODluvr"
MN
U sold the 04?
What?
Sure did, I've decided to go a different route on some things. Did a quick sale and had 5 emails in the last 2 days. I want to invest in a sick classic or custom hot rod. Kon just sat in the winters and only drove about 1600 miles a summer. I no longer had the passion. Id rather someone drive it and enjoy it all year. Its still in my shop and they are picking it up monday.....
Jiggy-J
Fosscore
Understand. Sweet ride for someone else. Bet the interest was good too. Well good luck finding that sweet classic. Im sure it will be sick like your other project. Good luck man.
Yuko04
"SquareBODluvr"
MN
Thanks[emoji106]
Jiggy-J
Smoke Em All
Taylor,Texas
Bought it!! Well my second one anyway. It may look a little familiar since I bought it from @Tahoewhat! Now I have an 03 LT 4wd and 05 LT 2wd. Thanks Mike!
BADRIDES
Where can I find more pics of the build-up of the 04?
CKendrick
