Anyone used fiberglass before?
BlueTahoe2001
Charlotte, NC
Starting a new project for the inside of my truck. Where my little lid flips up right about the cup holder and holds the cassette player I want to install 2 Aero-Force Gauges in that area.
I was going to cut out a square are in there and then fiberglass everything back in and use a whole-saw for the gauge holes and paint it to match the interior.
So, Has anybody ever done fiberglass work before that can give me a few pointers on how to accomplish this?
Thanks
ecordell
CordellDesigns.com
Merica
I've done a little fiberglass work, but it was on a fresh build with MDF board and then used the cloth you stretch and then pour the fiberglass resin over it......as far as what you're talking about I haven't.....
BlueTahoe2001
BlueTahoe2001
Charlotte, NC
Ecordell, Got some more information and pics? I need to build a sub box as well and was thinking of using Fiber Glass for that.
mikeyboy
freeport new york
mix it right or u will be sorry scraping the resin out ...marine tex might be easer to use and work with its pritty much the same but a lil thicker so it tacks better and its a 1 to 1 mix
nytahoe
"Tha Butcha"
new york
i did put a screen in my 03 not hard but ive done a lot of fg work
---------- Post added at 09:03 PM ---------- Previous post was at 08:58 PM ----------
yukonjacks
A Vegitative State
The Confluence
Check the classifieds theres a guy selling them cut out for screens, maybe he can make what you want, in the mean time Ill look to see if I can find the ad
ecordell
CordellDesigns.com
Merica
Sorry man, I don't have any pics, but basically we built the sub box and then there were exterior trim pieces....we took the matting and stapled it to the mdf sub mounting ring and stretched it up over the exterior trim pieces and then stapled it there. this gave the basic shape that you'll get, then just put the resin on with a paint brush and it hardens. Sand is smooth (but not too much because you'll go through it) and if you need to change things you can do it with fiberglass filler. Once it's all smoothed out you primer and paint it.. you get quality like the screen shown above....
JKmotorsports
Austin, TX
If you are going to paint, the surface needs to be as smooth as possible. Once you paint it, the paint will usually show flaws that you didnt see before. Use a body filler to fill in any pits and/or smooth any ripples or slight waviness. Once you sand it all down with the body filler, you can go over it with a filler primer, sand, then check for any left over pits.
If you're going to build a sub enclosure, keep in mind that fiberglass across a large flat span is a lot weaker than the same surface area that is curved. Make sure you reinforce it accordingly. You can use fiberglass cloth/may across large flat sections and use chopped strands for curves and irregular shapes.
Mixing the resin with the right mekp percentage is important. Too little and you'll be waiting forever for it to cure. Too much, it can cause the mixture to shrink and crack, just like plastic body filler.
Whatever material you choose for your project (t-shirt, fleece, speker grille cloth, etc), make sure it is completely soaked through with the first application of the fiberglass resin. Let it cure, then you can start applying more layers and fiberglass cloth in between layers of resin to strengthen the piece.
BlueTahoe2001
BlueTahoe2001
Charlotte, NC
JK,
Would it be ok if I did a square box, then used a wooden ring to "out-set" the sub? Would this help with the Fiber Glass being stronger? That way the fiber glass is not stretched on long flat surfaces and still retains surface strength?
JKmotorsports
Austin, TX
If you're building a simple enclosure, use MDF or birch for the flat spans and then you can use fiberglass to get the contours you want on the baffle. Try to restrict fiberglass usage to contours and irregular shapes. When using MDF for enclosures, you can brush on a thin layer of fiberglass resin on the inside panels to completely seal the enclosure. MDF is still porous and can leak air. A layer of resin will seal it.
BlueTahoe2001
BlueTahoe2001
Charlotte, NC
Cool, So in a nut shell Fiber Glass is a no-no for flat surfaces? Contours and Irregular shapes only?
Also, Just to double check, I am building a box that is 12x12x9" Is that to much flat surface to use fiber glass. What is the max flat surface you would use FG on when still trying to achieve strength?
The reason I ask is because I would like to get the finish of FG on the simple box I am building. Just to give it a custom look.
JKmotorsports
Austin, TX
You can use 'glass for flat surfaces, you just have to reinforce it more compared to curved surfaces. The larger the span, the thicker you need it, especially for sub enclosures.
A box the size you're building would be ok to use fiberglass, but it would be much more cost and time efficient to use MDF. If you want to paint it, you can brush on a couple thin layers of resin first then paint it. From what it sounds like you want, I would build the entire box from MDF and cut the opening for the sub. You can then build a trim ring for the sub to mount onto to raise it. Mount the ring to the enclosure, stretch cloth over the top to give it the shape, then apply resin to the cloth. Once you finish applying the needed layers of resin, you can cut the opening for the sub, sand it, finish it, paint, then mount your sub. This way, the sub is directly mounted to the MDF enclosure for strength and the finished 'glassed cloth will be there strictly to break up the square look of the box to give it a custom look. Doing it this way will help prevent unwanted flexing of the walls and provide optimal strength by using MDF and provide a custom look with the slightly raised, painted fiberglassed baffle. This will also be a lot less time consuming than building a completley fiberglass only enclosure.
syndicatesteve
Syndicate Steve
Southern California
aint nothing like the smell of a fresh fiberglass job on your ride. for flat surfaces use strips of fiberglass, and for curved ares use " chop" its stronger and offers more surfaces for strength. also dont mix the glass to hot or the end product will be very brittle
BlueTahoe2001
BlueTahoe2001
Charlotte, NC
Sweet, Thanks for all the information! This will come in handy when I get to building the box this week!
johnsonwillie199
