shakedown067
Swapping to color-matched door handles. Hope to get the front doors installed tomorrow. Will have to find a rear hatch handle later.
BillBlatt18
Latham, NY
Some black depo headlights would really set off the front end.
Have some chrome depos on the way! Had black ones in and wasn't too sure how I liked it. Sent them back and ordered chromes[emoji108]
jcevans7
Friendswood, TX
Changed out the knock sensors. YouTube was good leading me to believe about 2 hours would be enough. It was not everything was good minis I broke this guy.
I have a game called whafs this name...
it connects to the fuel regulator
Sent from my SM-N910T using Tapatalk
#1taho
5150TAHO
niagara falls ont
Did you get the part you broke and finish the job?? If so how does it run ? better ?
jcevans7
Friendswood, TX
Had to jerry rig the fuel vacuum line. If I'm wrong by the name let me know trying to find one online. I used some heat shrink tube it works in a pinch but not a long term solution. Here is a better pic of the line.
#1taho
5150TAHO
niagara falls ont
To bad you are so far away. I would give you one. Any local wreckers should have one.
seven9st surfer
Milton, FL
Did a lot. Washed and waxed after last weekend's road trip. I designed and made a center console organizer out of 1/8" HDPE. Attached a Grid-It organizer to the underside of the lid of the console. I also made a magnetic iPad mount out of more HDPE and an old Scosche mount I had laying around that slips into the CD slot of my head unit. And I swapped out my XB35 ballasts for the XB55. And I test-fired and sleeved the high-beam triggers for my new Morimoto Mini H1 7.0 projectors. All I'm waiting for to finish that retrofit is the adapter plates.
#1taho
5150TAHO
niagara falls ont
Before
After
This is how it should have came.
15 minutes to take off the old glass and corners and reinstall. I took off the old third tail light off and put the screws back in so no water got in. Pull the harness out and unhook and hook the new one on. Quick and easy.
raviel119
New Jersey
Before
AfterView attachment 57669 View attachment 57670
Looks great! I get a little jealous at seeing all your guys mods. I have an Esky and I feel at times there's nothing for me to do. Lol. I have all those things you guys mod to. I do have to replace my clear eyes taillights soon I like the look of yours. Maybe they make a version for the Escalade?
#1taho
5150TAHO
niagara falls ont
I am sure there are. Mine came with the truck but I have seen them in multiple different styles. Caddy is the best. I just not a fan of the AWD. But love the rest.
Big Jim
