Need help with my autocal!!!!
Nosho47
I have been trying to contact blackbear for well over a month now and with no help. I called and been told to give them an email. I have sent numerous emails with no response. Has anyone else had this problem? The problem I am having is that when I even try to have it read my ecm, it says error280 or error281. If anyone have had this problem, lmk cause this is getting irritating since I am not able to use my autocal after paying a good amount of money for it.
Sent from my XT1080 using Tapatalk
about20ninj45
Have you tried updating the software?
N
Nosho47
Yes... I tried updating the software and it still doesn't work
about20ninj45
N
Nosho47
I have an airaid Jr intake, headers with no cats, exhaust and will probably get cams installed sooner or later... The lighter fuse is good and not burnt
about20ninj45
i meant like subs, amp, car alarm, anything electrically added that wasnt stock
N
Nosho47
Yes... I have subs, amps, head unit, door speakers ...
about20ninj45
As stated in those links, disconnect your amp a unplug your fuse for your radio. For whatever reason, they interfere with the communication with autocal and the ecu
JennaBear
Resident Ninja
San Diego, CA
Were you able to get this figured out? Multiple emails will keep pushing you to the back of the queue, so that is what would have increased your wait time. What email are you sending from? If you have been waiting for a month, I would like to see where the issue is.
N
Nosho47
I have not been able to do it yet because of my work schedule... I'll probably have to do it on the weekend. If it does not work, I'm gonna just go with the traditional and get the ecm programmed...
JennaBear
Resident Ninja
San Diego, CA
The guys can remote into your computer to help you figure out your issues.
But is does sound like your aftermarket radio may the culprit (it is probably drawing power).
Otherwise, you may be using the wrong configuration- trying to use a 2008 on a 2006 for instance, they would not be able to cross talk.
Shoot me a PM with your email you have been sending from so I can try to run it down.
JamesinAbilene
