Question about LSA SuperCharger
about20ninj45
Hey folks, I was wonder about pulley combinations to achieve more boost from a supercharger. Im thinking about scrapping my twin turbo build in favor of a blower and instead of shelling out a huge amount of funds on a tvs 1900 or 2300, I've decided to go the route of purchasing a Lsa blower from an 2010 cts v. Question I have for starters, is that blower an eaton blower? And whats the max boost you can run on that blower via pulley swaps? From what i read, stock boost is at 9 psi. Please help me out.
ezdaar
Chat Troll
Redneck central, Aka Houston
Is a repackaged tvs1900.
You can get well past 15psi with it.
Hope you understand that its a square port and your heads are cathedral port.
There are adapters on ebay.
Or you can just swap the heads.
This is not a simple plug n play blower on your vehicle.
Your better off buying a used maggie from someone on performancetrucks.net.
about20ninj45
about20ninj45
Thanks! I already knew about the adapters from cathedral to square, but I have l93 heads. I think the original 6.0 heads makes more torque down low. I know I'll need an accessory bracket modification. Along with other small things, but the price was to good to pass up. I'm on performance trucks everyday, and I think the lowest I seen for a maggies was 3600
ezdaar
Chat Troll
Do a search for lsa conversion kits. There are a few guys who sell them with or with out the charger.
Decent price point aswell. Considering you get every part needed.
I am un sure if the parts are genuine gm tho.
As far as making more torque, lol come on man. Your abput to bolt on a blower and jack the boost! You will have plenty of torque.
My friends cts was well over 1k tq.
Ported quare port heads, decent cam and as much boost as the blower can make. Its making over 600 at alil over 2500.
Well that and a 250 shot. :)
Be warned tho. That much power on tap off idle is killer on the stock bottom end. He just crushed a handfull of main bearings the other day. It lived for aprox six months,mbeating on it daily. Then he hit it with the juice during a launch and killed the bottom end.
about20ninj45
about20ninj45
My goal is 650 ish hp and tq. I won't be on it like that, just want something to wake my truck up a bit while I save more for my 418 build for this Yukon, but that's a little later. I believe the stock bottom end on an iron block should be able to hold more than an aluminum stock block, could be wrong though
ezdaar
Chat Troll
Your correct.
Look up the problems with the OEM blocks when building strokers.
At the bottom of the crank stroke the piston skirt comes oit of the bore to far.
It excessivly wears the bottom of the cylinder and the the skirts of the pistons.
Yes alot of guys have been stroking these blocks for many many years.
Just want ya be aware of this one problem if you didnt know about it already.
Its not a super critical issue, but ot does bring up longevity concerns.
about20ninj45
about20ninj45
Your correct.
Was kinda worried about that for as well, what block do you recommend then? Any suggestions on that route?
about20ninj45
about20ninj45
Good watch if ya have not seen it yet.
Will let Mr. Nelson tell ya.
LSA conversion for those who dont hang put on PT.net
That was possibly the best unproductive 20 mins of the day lol
I think livernois motor sports mentioned this to me as well, but i wasnt listening to that guy. Seems like unless your doing a tall deck, it should just be cam, heads, tubes, and tune....
ezdaar
Chat Troll
Meh, first time I watched it, I enjoyed it..
Next vid I post for ya will have bikini's and LS engines in it.
Honestly, given how cheap a short block is these days. I would just stroke it and go.
Just watch oil 20-50k miles, for aluminum.
Save the $$ for your 418, then go the tall block.
about20ninj45
about20ninj45
tHANKS A TON!
LSA blower is inbound in about 20 mins!!!!
will post pics once its here
bottomline2000
Dallas, TX
tHANKS A TON!
there was a thread on tech and it got blocked or something. last I saw a guy with a tahoe completed the lsa swap and it wasn't anywhere near the cost of a used TVS..post updates please!
shakedown067
Ls9 cam, smaller pulley, zl1 lid, and a good tuner you should be able to push 600 real quick. A friend and I are currently collecting parts for LSA 5.3s. He hopes to have his done by end of December and plans to be over 500hp with the 5.3. I'll be happy with anything over 400rwhp. Just wake up the passing power.
Friends build, but with my CTS-V lid. 5.3 with 241 heads, 4.8 flat top pistons, and ls9 cam.
about20ninj45
about20ninj45
Why the ls9cam though, you lose bottom end torque when not in boost
shakedown067
Compared to what? It's much better than the stock cam across the board and is dirt cheap when it comes to cams. Even swapping to the front cam sensor and timing chain cover. The ls9 cam is a 33hp gain over the lsa cam for the Cts-v owners. I'd rather make more power across the band. I think it's hot rod magazine that did a big article on all the GM cams, but was in a 5.3.
about20ninj45
about20ninj45
But I wonder if that same claim can be made on the 6.0 as its torque what you want for a heavy vehicle, not hp
shakedown067
I've actually decided on the LSA cam. Slightly better low-end power and torque, but drops off at 5,000 rpm where the ls9 continues to pull to 6,000. Don't need that in the ole suburban. Hopefully just got a cam and throttle body off of a CTS forum.
The fairly flat lines are the LSA cam, the rising lines are the LS9.
Ossipeelake
