ivin74
05 NBS Nali
I'm looking to upgrade my headlight bulbs w HId's.
Is anyone using the HID kit from XenonHIDs.com
Morimoto hids from theretrofitsource.com
Any reference or tips for setting the distance (up/down/left/right). Say if you park 5' from a wall and measured the cutoff to the ground and width of the 'half moons'. That make sense?
View attachment 57196 View attachment 57197
PS: Using generic 55w WYH stamped in the Yukon with aftermarket halo/projection housings (Illustrated above) They don't last long unless you waterproof them yourself.
Using 55w OPT 7 (in the Tahoe) they're great and last a long time!
Currently using 3 DDM kits. (Lows - 6000k, Highs 4500k, Fogs 3000k) I will be doing a quad retrofit this winter with Morimoto Mini H1s from TRS. Probably go with 6500k on that. Not sure yet. Doing a retro on moms sequoia for Xmas with 5500 so I'll see what hers looks like when I'm done.
What all do I need to buy to fo the retro fit?
ivin74 - Good question as I haven't seen much on this either. Maybe ezdaar can post a few links with his expert searching skills.
