No idea what this is
Dr Banana Maann
Ok so digging around under the dash I cam across this strange chip that when out just disables the start on part on the ignition. It attaches to the Yellow wire which I believe is the "Crank" wire. There are 4 other connections. 2 going to the same ground post, another 1 the red wire is going to to this orange wire near the obdII port. the crank wire is cut and is being fed into a relay as well.
The chip itself is very small and has just 4 contacts if I recall. I will try and get a picture of it tonight when I have some time but I don't have a picture of the actual thing that is mounted on the underside of the dash as well as a crappy pic of the relay.
1996 Chevy Tahoe 5.7L, it does have a trailer braking system as well.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
it is either a fake key card reader or one that has been disabled. you would stick a key of sorts in it to enable the starter circuit. if it starts regardless leave it alone or remove it.
D
Dr Banana Maann
Alright, ill get some more pics tonight so you all can see a bit more. I don't mind leaving it will probably tuck the wires up a bit better
Richamos1
Northwood Iowa
It could be a low jack installed by a buy here pay here place. They install those so they can disable a vehicle if a customer doesn't make their payment and locate it to repo it.
JeffK
