TheAutumnWind
- Joined
- Jan 8, 2015
- Posts
- 3,254
- Reaction score
- 1,993
What dye did you use?For the dash, I washed it with Dawn, then a degreaser with scotch bright pad, wipe with a precleaner, and let dry in the sun. I used the scotch pad to try to smooth out the flaking edges as best I could and used the precleaner again (specific cleaner before dye is applied). I coated the bad spots first so it'd build up. You can still see a couple of spots on the dash, but they aren't really obvious any more.
Sent from my HTCONE using Tapatalk
