Cam swap or mild nitrous shot?
jmildoc
Indianapolis,Area
well the cam cost over $400 plus you might as well do it the right way! so that puts you over 500 or close to $600 and that is if you do it yourself. and you can get a new nitrous kit for about $500 shipped, go with the NOS and blow the doors off him
tybardy
everyone needs a Hoe
Gilbert Arizona
you mind pointing me in the right direction of the $500 nos setup?? i want to see, just for funsies... all the kits i have looked at are closer to $900 and $1000
road1will
pretty pretty good
Johns Creek, Georgia
I have a kit at home that's cost me about 500. I'll get the model number for you later on.
blueflamed03
Oklahoma
what about refills.............if you wanna win once, sure, add a bottle and spray it....cam,etc, use it ALL the time.
Max
Mile High
Denver
these go on sale from time to time, plate kit so you can hide the solenoids under the engine cover
http://www.harrisspeedworks.com/shop/product.php?productid=387&cat=135&page=1
I'm gonna run this switch panel if I spray mine
danimalmax
louisiana
after the LT and cam install, you'll want it retuned.
Look around, there are several places that make killer cams. Comp, TR, Vinci, etc
Longtubes? I plan to try the LPP's, stainless, and come with ORY for $500! That's a great deal.
If you have 3.73's, your good...cam and headers will make the biggest change.
Cam, springs and get hardened pushrods...leave intake and heads alone, for TQ, the heads are more than adequate.
danalimax, I have heard 50+ HP with cam and headers
---------- Post added at 09:18 AM ---------- Previous post was at 09:10 AM ----------
mild cam
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=1095&sb=2
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=1085&sb=2
Vinci cams
http://www.vincihighperformance.com/camshaft spec list page ls truck.html
if leaving converter stock, the Vinci 080 is perfect, installing a TB stall, look at the 112 or 062.
---------- Post added at 09:18 AM ---------- Previous post was at 09:18 AM ----------
what about those thumpr or motherthumpr cams? are they just for noise or is there more power? if i get a cam, i think i want the most power i can get, regardless of noise
tybardy
Gilbert Arizona
hey max, that is a sexy little switch panel... i have 4x4 in that location though... i have the cutout where you have the tracktion button... but anyways, having the bottle would just be fun for fun sake... i think if i have $500 i might pickup a set of those lpp long tubes... they looked like a nice package for the money.
JennaBear
Resident Ninja
San Diego, CA
I have a CompCam 206/212 115LSA and AEM Sport LT headers. The cam worked great with just the headers and is even better when force fed. Good way to ramp up.
JennaBear
Resident Ninja
San Diego, CA
Not much, but you should be able to call any cam vendor and get them to suggest the best cam for your setup/wants.
Max
Mile High
Denver
If I spray I'll go 150, it'll have the fuel system so why not?
danimalmax
louisiana
forgive my ignorance, but when u press that button, you instantly have plus 150hp on top of your stock for however long the bottle lasts?
johnsonwillie199
