Please Help w/ HID Issue!
Clean07Burb
So today I received my kit Morimoto H11 5500k HID kit w/ relay harness from The Retrofit Source and decided to install them since I had some free time after work. I installed the kit, and turned on the headlights, but only the passenger side fires and lights up. The driver's side ignites and then immediately shuts off each time the headlights are turned on. If I unplug the ballast while the headlights are switched on and then plug it back in, I get the same result. A slight flicker of the driver's side bulb and then off. I thought maybe I had a bad ballast or bulb on this side, so I switched them from one side to the other. Same result. The problem remains on the driver's side only. So then I thought bad ground on this side. Nope! Wired the kit straight to the battery and same thing happens. One fires and the other doesn't.
Then I wondered if something was wrong with the relays or relay harness, so I eliminated it just for troubleshooting and wired the ballasts directly to the factory headlight plugs on each side. Got the same result of only one side working, but this time it was the passenger side that didn't work and the driver's side worked just fine. Weird!
I'm stumped. Called The Retrofit Source and they're also stumped. Anyone have any similar issues installing an HID kit w/ relay harness on their NNBS? Any wiring guru's on here that have any suggestions? Or is there some trick that applies to NNBS trucks that I don't know about when it comes to installing HID's on our trucks? I thought I had it made ordering a better quality kit from TRS and had an easy install ahead of me, but, apparently not. I'd appreciate anyone's input or advice!
ETA: I've also gone over each and every connection and all seem to be making contact just fine. No loose or bad connections anywhere.
C
Clean07Burb
better ground on both sides
As I mentioned, thought this could've been the problem, but I wired the kit directly to the battery and got the same result. Doesn't get much better than getting both hot and ground right from the battery, but it didn't change anything.
felixgun
Lafayette, LA
Omg this EXACT thing happened to me!! So glad I'm not the only one. Jeez this has been so frustrating.
C
Clean07Burb
So have you found a resolution, Felix? I'm kinda pissed that its not working! I don't believe its a problem with the kit, I think its maybe a voltage issue with our trucks or something. I don't know. Seems like we're the only two with this problem because I know tons of NNBS guys with HID's and theirs are trouble free. :(
felixgun
Lafayette, LA
I did mine in my 2015+ but have the same issue. All bulbs and ballasts work ONLY on the passenger side. If I unhook relay on driver non working side it will work until car turns on then it starts flickering. My troubleshooting is telling me it's a bad HD relay cable.
C
Clean07Burb
I thought about the relay harness possibly being bad, but I bypassed it by hooking each ballast directly into each factory headlight socket(essentially making it like the older kits w/o relay harnesses) and got the same result, but the problem switched sides. When hooked up this way, the driver's side now works, but not the passenger side. Exactly the opposite of how it functions when using the relay harness. Its really odd. I've racked my brain, but haven't figured it out. Yet...
Let me know if you find a solution or even if you decide to replace the relay harness and it happens to resolve the issue. I'd really like to get mine working!
felixgun
Lafayette, LA
I'm hoping TRS sends me a new HD relay and that really is the problem. If that's not it I have no idea what else it could be...
ATIII
Brighton, CO (Denver)
Im having the same issue, driver side LO flickers only, intermittently. gonna try to run some inline capacitors.
felixgun
Lafayette, LA
TRS support replied to me saying to take out the individual relay in the cube on the HD Relay harness and switch them to see if it's the actual relay itself or the cable. It's something I didn't troubleshoot because I didn't know you could take them individually out.
---------- Post added at 12:43 PM ---------- Previous post was at 12:43 PM ----------
They said one capacitor should be enough.
01Konvict
Boats n Hoes
Raleigh/SML
Seems like the relay or wiring is an issue. I hope I don't get this issue down the road on my retrofit
C
Clean07Burb
I already switched the relays around and also swapped in two brand new relays of my own and it didn't change anything. I also wired the ballasts directly to the factory low beam pigtails, totally eliminating the entire relay harness, and got the same result of only one side working, except it was then the driver's side that worked and the passenger side didn't. Opposite of how it is when using the relay harness. This is a really weird problem and I'm glad to see I'm not the only one experiencing it. Looks like theirs a few of us with the same problem.
01Konvict
Boats n Hoes
Raleigh/SML
Did you swap ballasts from original driver side issue to passenger side when direct wired to battery?
Or did you swap bulbs? It could be a bulb acting up.
08grey
One capicitor per ballast and your good. No relay harness needed. Once in a while you will have one side out if it starts with low voltage but other than that your fine. I install them without harnesses all the time.
C
Clean07Burb
Yes, I swapped every combination of parts from side to side with no change in function. The driver's side never functioned when using the relay harness.
---------- Post added at 05:55 PM ---------- Previous post was at 05:52 PM ----------
Still didn't work. I wired the ballasts directly to the factory low beam pigtails using a capacitor on each side and got the same result of only one side functioning. Only wired this way, it was now the driver's side that worked and the passenger side did not. All testing was performed with the truck idling and producing between 14-14.5 volts. This is why I'm at such a loss. It makes no sense.
ezdaar
Chat Troll
Redneck central, Aka Houston
Send that shit back and get replacements.
johnsonwillie199
