Pics-biggest tires on stock suspension
Tribalbreak
WARminster PA
effeckt,
yes stock suspension, and the only rubbing i get is at full lock one way... the driverside wheel well has a slight bulge for the washer res. so it rubs just enough to take any dirt off the wheel well
AK,
No problem man
Denton
Waco, Texas
Whats the tallest tire I can put on these stock rims to fill up the wheel well? Will 285s be the tallest?
massivespl
I'm not mean, I'm honest.
Michigan
My buddy has 285/65/20 stock Tahoe just keys in front no rub
I've had 305/55/20 no rub
285/70/17 no rub with+12 offset.
305/45/22 no rub
275/65/20 no rub
33x12.50x20 no rub
Right I'm 33" off the ground with 305/35/24 no rub at all.
Lorenzo Hyman
Anyone know where you can widen a pp. steel wheel? I'm gonna widen the rears to 17x 9 or 17x 10 the put the biggest tire in the rear. yes its for my 2011 pp.
2003FatSo
I am getting new tires and maybe wheels for my Tahoe. I wanna see what the bigger tires look like and hear your opinions on what sizes will fit under the stock suspension. I want to keep stock wheels and suspension and fill that wheel Gap. I want to go with a 32 inch tire or a 285. I also want them to be a little wider with no problems. Not too wide but wider than the 265/70/17's what is taller and wider that will fit a stock truck? Also I wanna see some pics of your stock Tahoes with your bigger tires. I am also new here and my name is miles. I live in Athens Ga:Handshake:
Mine before lift with 285/45r22.
All terrains. Around 32.1 inch
No rubbing. Great handling.
I like Highway tires better
Now I have 3" lift in front and 305/45r22 AT and they rub
HeavyHoe03
