headliner
plasticman
How do you remove the headliner on a 2015 Suburban? Any tricks?
Want to remove the roof rack!
NathanJax
Vacation Nathan
Jax, Fl
bump for OP
NathanJax
Vacation Nathan
Jax, Fl
You are probably the first person to try
P
plasticman
Removing the roof rack!!
NowZoomer
You're removing the long roof rails? What goes in their place?
P
plasticman
Using SS machine screws with Silione, 5 Each side. Bought some 1" wide 1/4" thick Black
rubber side molding to fill the roof slots. Will post pictures after completed.
massivespl
I'm not mean, I'm honest.
Michigan
You have to remove the headliner to take off roof rack? Wow that sucks. My 2002 you don't have to take the headliner off... I'm curious to why did you have to take out the headliner to take off the roof rack on the outside of the truck?
TOYSTRY
Wow, I can't believe there isn't any sound deadening material installed on the roof.....I swear these American SUV's are overpriced for what you actually get.
P
plasticman
The older ones had threaded inserts in the roof, you could take the roof rack off and only have the threaded
inserts left. You could drill the rivets out and silicone flat top rivets in the holes. Was really easy. New ones are through
bolted with lock nuts. It does suck!! I guess you could cut the bolts, but then
you would have a half of bolt and nut laying on the air bags! could be some heavy
shrapnel if they ever went off!
NowZoomer
Looks great
You did this yourself, any easy is it to mess up and introduce new squeaks rattles etc - always uneasy with removing the headliner
gat0r
DFW
i had heard it was a chore to do,
but that did turn out quite well
is that a nomad , i spy? ;)
you have some nice rides
Drewphil
