2015i - Feb15 Build date and i have Antenna water leak? is there a temp fix?
Tommytuna
So the honeymoon period is over. I have had the 2015i LTZ for a week now.
Two issues:
1) Rough idle - looks like it can be fixed
2) More serious - rained yesterday and now I have a water stain above driver visor. So I guess I have the dreaded antenna leak?
I'm amazed given this was such a common issue that a Feb built truck wouldn't have this fixed???
Here is a pic of my antenna - I noticed a gap in the rubber seal where water could easily enter. Fortunately I turned up the heat in car and within 20 minutes it was dried out without a stain.
Is there any sort of temp fix I can apply - given long weekend dealer can't take me until Tuesday. Don't want anymore rain in there messing with electronics.
I'm pretty freaked out about having the headliner ripped out etc. Why do these antennas leak? Is it the rubber gasket?
GM: If you are listening - Love everything about this truck but these are bush league issues. GM you have to do better than this on high end product.
ANy tips would be appreciated to get through next few days.
I'd have that thing in the dealership asap! that'd be my fix.....and NO GM is not listening or reading this forum LOL At least, not anyone that can do anything significant LOL
T
Tommytuna
Yah but everything is closed here today and tomorrow we're out of town for couple days.
Wondering if there is a temp fix? I am 95% certain it is that antenna as the middle of the of leak stain was right below centre of antenna. I can't understand why they would intentionally leave a gap in the rubber gasket. Is there some temp silicone I can put in there?
Some other forums actually have people getting replacement trucks due to this issue. Does GM actually provide a new truck on issues like this?
Well a temp fix would be putting some silicone in that gap where you think the leak is coming from. With that said, if you do that GM may find it to be a convenient way to blame you for the issue since they won't be able to "prove" that you didn't fiddle with it prior to the issue occurring. If it's me, I leave it as is. If the problem gets worse then it gets worse and therefore more on GM to fix for you. If that means a new vehicle then that's a plus for you........and this is the first I've heard a dealership being closed on a Friday whether it's Good Friday or not LOL
T
Tommytuna
Very true.
When you guys (without leaks) check your antenna, do you have that little gap that I have (see my pic - it is quite obvious). Otherwise antenna seems properly seated.
Good Friday in Canada - just about everything close.
If it is just the seal, do they just replace seal or do they always replace the entire antenna? I heard of others having to wait for new antennas and have them painted etc.
OnStar/GPS and everything else working well.
Logically thinking they'd just replace the seal and any damaged parts (headliner, visor,...) but knowing GM they'll replace you're entire antenna housing and all your lug nuts just for good measure. LOL
NathanJax
Vacation Nathan
Jax, Fl
I would make them replace the entire liner. Tell them that there will always be a ring there where it got wet
T
Tommytuna
Liner looks totally fine now that it is dry. Do you guys have that same gap in the rubber seal that I have in my pic?
magiaone
duck tape to seal it for now - if you put silicon on it - they ll have to scrape it off and then scratch the paint............jmo
NathanJax
Vacation Nathan
Jax, Fl
wouldn't do duct tape, that would leave residue. I wouldn't use silicone either though. maybe painters tape?
Do you guys have a gap in the rubber?
Jacob and I are 07-14 guys just trying to help out
T
Tommytuna
I am thinking some of that putty u can use on walls to hang pics. Comes off with no residue?
Can someone take a pic of their antenna plz
T
Tommytuna
Well one positive is the issue forced us to clear out garage so we can park the beast indoors. Been putting that off for months:)
I wont put anything on the seal and will try to take it to dealer tomorrow.
Bummed out but luckily caught it before a major rain storm.
T
Tommytuna
Is There an official gm bulletin for this leak issue? I have seen others on talk about dealers doing different things ranging from a silcone fix to replacing with a 'reengineered' antenna. Others claim success after DIY plugging of the rubber gap. I am goig to dealer on Monday - would like to be armed with all the info possible.
Jake01
Virginia
I had the leak. It's not that gap you're referring to. It a bad seal or they didn't torgue the bottom bolt tight enough on antenna. It's an easy fix but annoying while you have it.
October
So is that gap normal design? The roof slopes into it, so water would have a tendency to flow down into the gap. Doesn't make sense from a design perspective.
T
Tommytuna
Interesting that you don't have the gap at the back of the seal.. I always thought it shouldn't be there as a I looked at other cars and none of them had a cap. The gap must be there to allow for some ventilation?
That being said, I looked at a brand new Escalade and a few other Yukon/Tahoe's in the dealer lot and every single one had the gap. Blows my mind they would be shipping them still with these crappy seals.
Mine gets the fix done today.
wwiizz
