Esky / Denali Console Finally !!!
Kramlik
IL
Finally Found A Console After A Year Or Two Of Looking And Refusing To pay Ridiculous Ebay Prices... 20 Minutes From The House And For Only $30
Its A Little Worn And The Wrong Color. Im Gonna Clean It Up Repaint And Put New Vinyl On The Lid... Will Also Have To Come Up With Some Kind Of Home Made Latch Since Its Broken, Ooh The Rear Cup Holder Is Missing :/ Will either Fill It Or Try And Figure Out Something Else Charging Ports Maybe Idk Taking Any Suggestions On That
Im Just excited I Finally Found One And For The Price
And I Know You Guys Have Seen A Hundred Of These Threads
Kramlik
Kramlik
IL
Took It apart Gonna Start The Cleaning Process
Kramlik
Kramlik
IL
Someone On Face Book Mentioned That I Need To Get Part Of The Air Duct From The Escalade Thats Right In Front Of Where The Console Was And Swap It Out With Mine So The Heat Or AC Blows On Either Side Of The Console Instead Of Right Into The Console So I Still Need To Pick That Up Waiting To Hear Back Hopefully They Still Have It, Only been Two Days
qukon 95
if you want a good hidden subwoofer for your system wire that sub up its a 1.4 ohm sub
so you will need a 1 ohm stable class d amp i use mtx 1-350 rated @ 350 rms@1OHM any thing bigger may blow sub theres no specs on power handling for this sub. i set LP to 100 hz and you will need to use sound deading on the console panels to cut down vibrations
from this wonder sub.
jerryjoe28
That Guy
cabot AR
yes you need the little deflector. without it the air will go inside ot the console not around it
t3amcha0s
where do you get the deflector? i have one in my yukon but i think i am going to sell it
Kramlik
Kramlik
IL
Get One From A Denali Or Escalade That Had These Center Consoles In It.
Its Just A Little Piece Of The Air Duct.
If I Cant Find One I'm Sure It Wouldn't Be To Hard To Make Something To Deflect The Air.
Kramlik
Kramlik
IL
Bought The Vinyl And Foam...
Also Got Spray Adhesive, SEM Sand Free And The Grey Color Coat.
Still Have To Get The Old Paint Off Of The Center Console, Was Going To Pressure Wash It Off But The Water Froze At The Shop So Im Gonna Have To Wait On That... I Can Start On The Lid Tho. I Bought Extra Vinyl Since This Is The First Time Ever Doing Something Like This Im Sure Ill Mess Up At Least Once But Hopefully It Goes Smooth !
jerryjoe28
That Guy
cabot AR
you want to sell one? where do u live?
yes im sure you could just make one its just a flat piece of plastic with edges flared out
bowtiefreak
No Quarter
Near Philly
nice! I have one in each of my trucks. Awesome upgrade with an OEM fit. One of my trucks has the new floor vent to bypass the console, the other does not.
ekylypse
Im Actually In Rockford LKQ Has A Few Denali/Eskys ?
I had blinders on looking for a multi-function switch and 3rd brake light, but I did pull some woodgrain & window switches from a denali. It was bitter cold and only stayed as long as I had to. lol. It was a 4dr denali with esky seats. I go every couple of weeks between my cutlass, the 'hoe and other random vehicles. They have a list of what vehicles they have and you might even be able to call them and find out for sure.
A fellow Rockfordian. Awesome.
Kramlik
Kramlik
IL
Nice ! Thats Pretty Cool Man, My House Is Actually In Machesney But Grew Up in Rockford Moved Recently My Lady Lives In Durand Im There Quite A Bit
NathanJax
Vacation Nathan
Jax, Fl
This isn't done yet?
:yaoface2:
rossida
