blew my rear end in my truck
jonah023
so i blew my rear end out a couple of days ago. im going with the detroit truetrack posi and 4.30 gears and the rebuild kit from http://www.ronsmachiningservice.net/ anything else i should do while the truck is under the knive. what kind of rear diff cover should i go with. also what diff oil should i go with. please let me know and anything to be concerned about .
ccapehartusarmyINF.(ret)
Gilbert AZ
4.30 gears whoa what were you trying to do with a monster gear ratio like that? driving up a vertical cliff or towing the state of texas
J
jonah023
I have 22s on right now and a heavy system. Guy from rons machine shop said I should I go with 4.30s
J
jonah023
My truck is rwd what diff cover should I go with guys need help ?
mattluttrell
I only put fancy diff covers on my rock crawler where it needs them. Why not just paint the stock cover and use it?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Agreed. Run the stock one that works fine since nobody will see it anyway and use the $$$ elsewhere.
J
jonah023
Ended up going with the g2 rear diff cover guys thanks for the input. What gear oil should I go with and there saying don't run synthetic or it will void the warranty.
SLCHOE
Midvale, Utah
Why would you NOT run synthetic oil? It's just superior lubrication on every level. With those new gears and TT inside there I personally wound not run anything else.
mattluttrell
G2 is nice. I have that cover on an axle. I usually run generic 75 or 80-90 oil. I don't do synthetic as it isn't needed. Check Detroit's recommendation. I know ARB required something different.
The purple oils (Mystic or Royal Purple) are considered premium I believe. Mystic is cheaper. I've ran that a few times.
J
jonah023
truetrac says dont use synthetic or it will void the warranty on the posi unit .
A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil. Friction additive/modifier is not required.
Drewphil
