"Service 4WD" - Master Thread
Terrell2014
Copy this from my post in general forum. New here. Yeah. 964 mile an it started for me.
((( Backing out of the parking spot it seemed 4 wd was engaged. you know that binding/grinding tire sound on dry pavement thats horrible. Anyhow the vehicle dash then popped up with Service4 wheel drive light on info center.
I was in Auto. I tried going to 2 wheel drive. Tired 4 low, 4 hi. None of the lights on the selector switch lit up other than auto. On-Star was of no help- at ALL.
Fortunately I "know" my sales guy and texted him of my issue, he was out with guys from the dealership and had a tech call me right then at the parking lot I was sitting in (now thats service). We worked thru it with a few suggestions and no go- it was in what we assume 4 Hi. I had to drive home 68 miles like this. straight was fine, turns were pretty nasty filled with grinding noise and that 4wd on dry road feeling.
I am sure it's some goofy switch? Maybe a software thing? but with 964 miles on the clock I'd expect none of these issues? I love my vehicle- but is this the ride I am in for the next 100,000 miles? Anyone else have issues this early in ownership?))))
And more from General thread.
((((((Just got my vehicle back from Dealer. Talked to the tech, he said it was a known service bulletin that the Transfer case NEEDS reprogrammed.
*Reprogrammed TCM (cause)
Conducted Transfer Case Control Module Reprogramming with SPS
In talking to the tech, said he has done 3 of these so far and expects that all of them just need it done.... ))))))
humer101
NJ,USA
I got it done 4 times, next time I told GM will live in the dealer up to they fix my car is pay already and will start a legal action.
hosseface
Good luck with that one. TONS of guys on here have been through that same ringer and it just keeps coming back.
I still CANNOT BELIEVE that GM hasnt found a fix for this yet. SMH
John1
'Service 4wd' message but no problems
my 2015 Denali was assembled in July. I received it in August. Shortly thereafter I got "Service 4wd" message every start-up. But it does not cause me any problems. I generally run in Auto. Runs good in snow and dry pavement. Figured I would wait till first oil change at 12000 miles to let the dealer sort out the error message.
After reading all the posts it sounds like more than one problem.
jeremyp
NH
I got the Service 4WD error message this past weekend at 1500 miles. When it happened I had been keeping it in Auto mode for the last two weeks without issue but while backing out of my sister's driveway I hit a patch of snow/ice and I felt a wheel slip a bit and then the error message popped up and I was stuck in 4WD.
I dropped it off yesterday morning and had it back at the end of the day with it reprogrammed and working fine so far. The dealer said they've been getting this problem a LOT. Not a good feeling...but I'll give it a whirl and see how long it lasts. I'm hoping this fixes it but from what I'm reading here it looks like that probably won't be the case. Has anyone had the reprogramming and NOT had the problem recur?
humer101
NJ,USA
My fight the first snow fall, very good but I just crossing my fingers.
[emoji19]
S
SVL
Libertyville, IL
Mine was last reprogrammed about 2500 miles ago, in Auto 4wd for about 500 of those miles, no issues as of yet.
JackTrills
Fort Mcmurray, AB, CAN
I am now a victim. 4wd service error pops up every time I start my 2015 Yukon xl denai.
500kms only in 6 weeks of ownership.
I have always kept it in AUTO and soon as the cold weather came in... 4wd service error always comes in when I start the truck.
I will have to talk to my dealership on Canada. Can anyone recommend any fixes?
Lyon
The dealer will reprogram the module that controls the transfer case (I think that's what it does at least) and it seems like that's the end of it.
humer101
NJ,USA
They will relearn the transfer case in 5 minutes and you good to go.
dirt-diver
No fix yet
Unfortunately, not the end of it. There is no true fix as of yet. The quick reprogram will simply get it out of 4WD. If you use 'auto' mode again, it can and probably will get stuck in 4WD once again.
Lyon
Oh crap, I thought, from following this thread, that GM had finally found a new flash for the controller that was actually working! Are you still having issues?
greg_tahoe84
At 4000 miles I got the Service 4wd error once again. And now when I put my car into park and turn off my car I feel a hard thump in my car. I am not sure if it is the transmission or something else.
HAARubicon
My latest update is working, so I think GM got this problem solved, make sure your service department has the latest updates and you should be good to go.
sub08
Queens, NY
"Service 4WD"
Got mine mid August and have 5300 miles to date.
I had same issue "service 4WD", 4Wd being active on 2WD mode.
I reset it by disconnected the negative terminal of the battery for a minutes and reconnected it. It stayed on 2WD but the Service 4WD comes up after every startup.
Will try to send it to the dealer for update and hope it works.
My too looks like they have solve. [emoji53] [emoji567]
So you're sad that it's solved?? :think: ...or did you just choose the incorrect smilies on accident?
Arkansas
Well just over 3k miles and the tahoe just popped the service 4wd error and is stuck in 4wd...oh fun...first problem with this tahoe...
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Hodmjstone
