Red_Raider
Derby, Kansas
No need to be sorry. I was tired of the chrome ones since that's all I see anymore.
Rivieraracing
Don't worry Red_Raider, JochenWoern is just mad because his rear window doesn't defrost anymore! ahhaha:jester:
dantheman
Houston
i also preferred the chrome rims over the kmc rockstars. I think a black wheel would look nice on there, but i just dont like the rockstars, mainly because the only people who run them in the houston area are highschool kids who are spoiled rotten or kids fresh out of college with a oil and gas job making money and wanting to spend it. and then they drive like dbags
---------- Post added at 09:39 AM ---------- Previous post was at 09:17 AM ----------
I have some like that. they are fine in reverse and turn applications, but as DRLs the leds burn out one by one fairly quickly. Mine are almost a year old and about half of the leds have burnt out.
here are a couple shots of the DRL replacements i got.
this is at night when unlocking it
during the day with the truck in drive
also added a relay harness for the HID's stopped the flicker i was getting as well as made the light pattern better overall. I dont think the HID's were firing completely off the stock wiring.
Ederela
Long Island
Clean and purchase
Cleaned her up and just purchased the RoughCountry 2" leveling kit should be in this week!
a4edwin
ny
Picked the turbo kit up from a member off another forum it has a magnum 76mm bb. 42lb injectors forgot what brand came also with electric fans and a Nelson harness. For the most part the kit is complete. Missing fuel pump and tune. Thinking about a walbri 400 trying to find somebody that can do a live tune in the area. Eventually the tranny will drop dead on me. I prob left some stuff out and once I get started with it I'll start a thread
Marv02
Ca
The UPS showed up with my Oil pan gasket at 4PM.
I installed the oil pan, New oil filter, rehung the front diff, installed the cross member and skid plate put the front tires back on put the Yukon back on the ground in an 1.25 hours by my self I was racing the darkness.
Tomorrow add oil and hope I fixed my oil leak, I am letting the RTV in the corner of the oil pan gasket cure up over night gives me that warm fuzzy feeling.
Lets back up a little on this past Sunday I took every thing apart and clean everything so I could put the Yukon back to getter easily when the gasket showed up today.
It took about 4 hours on Sunday to get it a part and every thing cleaned up so I would not have deal with it when the gasket showed up.
Oh got to love my air tools and yes I used a torque wrench.
I hope this will fix it I don't want to pull the trans out to replace the rear main oil seal the flex plate was dry so I think I fixed it.
Marv02
Ca
I don't have a external oil cooler it blocked off I resealed the block off plate just to be on the safe side.
I added oil this morning so far no leaks.
did you check the oil cooler cap/lines? flex plate being dry is a good sign.
redemn93
Jupiter, Fl
cool. yeah, same deal whether there are lines coming from it or not. mine is leaking. just haven't had a chance to get to it.
the real test is after you've driven a few times. hope it works for you.
Marv02
Ca
Thanks I am off work this week so I not driving it much.
But I don't see leaks like I had before you could see dripping off the bell housing.
rob3827
philadelphia, pa
I was on my way to work this morning and saw my buddy on the side of the road with another vehicle. They had a fender bender. When I went to check on my buddy, another vehicle struck and broke the driver side mirror on my suburban. I went to pep boys to pick up a cheap manual mirror. Changed it out when I got home. I also ordered new mirrors.....btw, Happy Thanksgiving to all
wwiizz
