NCTyphoonKid
Trinity, NC
Motor has less than 1500 miles, had a pressure test ran today, head gasket was good but I do have a slow leak. I contacted the original owner he said he also had problems with leaking antifreeze. I had a new water pump installed when the motor was built. I also contacted the engine builder and said he did do I pressure check on the heads so there were no leaks. I'm thinking the coolant tank or radiator is leaking, only thing it could be.
Damn that sucks try a new cap on the coolant tank first before doing the radiator or tank itself.
clandr1
Dallas/Fort Worth, Texas
Funny you should ask... I took it to the dealer to have them flush it, and the weeping started when I got the truck back. I didn't do it myself since it was done a couple of days before I changed the water pump.
dantheman
Houston
i did the 05nali aux input yesterday. but when i was putting the bezel back on i broke the tab off the damn aux input. so im redoing that today before i leave on a road trip.
interior LED's are at the house and i have to install them, probably on sunday.
YukonXL04
The Riverboat
Arlington, TX
Put my new water pump, radiator hoses and serpentine belts on. Also flushed all of the coolant out and put in fresh new dexcool. Yay! No more leaking water pump haha.
Also changed the oil on the wife's TL
Yuko04
"SquareBODluvr"
MN
Put the winter wheels on and hooked up the trailer.....something in store for me tomorrow. ...[emoji6]
Jiggy-J
I'm anxious to hear the outcome!!! :)
Yuko04
"SquareBODluvr"
MN
Keep an eye on, "your towing pictures"....[emoji41]
Jiggy-J
Pachanga02
Ny
Finally installed my brakes I ordered from freedom months ago on the rear and swapped 24s for Eskys(winter mode).
rebl68
SE Michigan
installed new torsion keys and 5100's. wanted to install rear spacer but had a tough time trying to get both to fit back in the pocket with no spring compressor. oh well - guess i'll order some z71 coils and try again soon.
dantheman
Houston
did LED DRL's and interior/courtesy lights. forgot to snap a pic of the whole thing lit up at night but o well.
the rear map lights i ordered were too long so i gotta order some different ones. i had an idea in the very back set. since i dont have a 3rd row, nor do i plan on having one, i am going put some COB panels back there. one in the cargo area and one on the hatch itself. so i can turn them on and off when i need them and have it put out some massive lighting when loading stuff at night.
Red_Raider
Derby, Kansas
Drove it for the 1st time in 3 weeks. Got to love the being to,d you'll only be gone for 5 days then it turns into 18 ( I got DOD problems). I will be installing new headlight and parking lenses as well as tinted tails from NeverSatisfied.
Marv02
Ca
I am somewhat late posting.
I worked on the Yukon XL this past weekend.
Replaced both Knock Senders (Fixed Service engine soon light).
Pulled out the brake control module and motor the top screws were stripped out so I had to remove the complete unit, took the Brake control module apart re-soldered the circuit board reinstalled everything flushed and bleed the brakes (Fixed the Brake and ABS Light).
Changed both diff fluid front and rear,
Greased the chaise.
Flushed the Power Steering fluid.
Flushed the coolant system.
Head light mod so when the high beams the low beams stay on.
It been a busy weekend there a couple more things I like to get done before the real cold weather hits.
Marv02
Ca
I didn't think it was bad at all worked on a lot harder thing's in the past I am a Aircraft mechanic by trade.
But getting Brake lines back on the Brake motor was a pain or the last line did not want to go on it took a while a extra hour or so for the one line to get it to start.
I went though almost 1 gallon of Brake fluid but hey the system is flushed out now.
With any luck you will not have to remove the Brake motor to get it out If you do just drill off the old stripped screws (Heads only) off lift straight up on the Brake Mod them just spin the old screws out they come out very easy at this point.
Do not try to use a easy out on the screws on this project it is more trouble than it worth just drill the heads off just drill down far enough the heads of the screws just fall off no deeper than needed.
I replaced them with a set of 4X07 MM Allen type head screws I picked up at Ace Hardware something like $0.20 each.
How bad was the abs fix? The videos online make it look like a daunting task..
OHSIXX
Milwaukee
Decided to go into wintermode early as winter apparently arrived early in the Midwest.....
OEM 17's plastidipped w glossifier. I also removed my DenaliDownUnder lower grille and re-installed the factory one along with my tow hooks. In the midst of changing wheels I noticed a puddle under my motor-thankfully it was just a bad OEM clamp on the radiator hose-replaced the upper and lower and added some coolant. On to the pics.....
picture.php
picture.php
JochenWoern
Sacramento, CA
As ALWAYS, ........... Nicely done J. Even in wintermode she is looking awesome!!
Merch619
