Buying a totaled Tahoe
M
maxamillion125
Easy kill. That center post might be in though, its probably going to need a slight pull. If you want to do it yourself, a large tree and a come-a-long. As far as the doors go - just replace them with used. Quarter panel - you can get a used quarter, end up doing more damage than needed to it, or just buy a new GM part. It will save you a LOT of time if you do the work yourself. Glue 90% of it, only welding around the tail light pocket and at the lower rear. Hopefully the hinges for that rear door aren't messed up, they can be a pain to replace. Also, that dog leg is going to need a pull too. Always do your pulls before cutting ANYTHING off.
As far as the value, I think I would buy it cheaper than $6k. Sounds like a bit much, given the work needed. Granted its an easy fix - but you're still going to have some good time and parts added in there. Id say own it repaired for $6k. Still going to have a salvage title.
---------- Post added at 10:43 AM ---------- Previous post was at 10:39 AM ----------
That's not a bad buy, the only thing that it being the same color will be good for is trimming out the door. They're still going to have to paint the quarter, front and rear doors, and blend the fender. Good luck getting the used quarter off in one piece without ******* it up. There is foam on the inside which has one hell of a bond to the metal. Only way to get it to separate is to hit it with the torch, which, if you're careful you can do it. If you've never done it before, you will easily warp the metal. Now you're throwing filler in it. More work, more time, more money.
---------- Post added at 10:45 AM ---------- Previous post was at 10:43 AM ----------
And Im not trying to discourage you, but have you ever done body work before? Its going to take a bit to get that quarter right, and that dog leg.
The center post and door hinges appear to be straight, I took a close look at them today. I did some research and like you said the Quarter panel is gonna be a SOB to replace. I might just replace the two doors and have a body shop straighten and quarter panel best they can and paint the scratches.
fiatdale
Houstons Best
Houston
Quarter panels on these are extremely easy, good money makers if you know what you're doing, because you can replace the whole panel. No sectioning. Once the glass is removed you need to grind down all the spot welds and like I said, you can glue 90% of the new panel on. If you've never done body work - don't try it. If you want a shop to straighten the panel, it's going to be full of filler, I don't care how good they are. Maybe that's ok to you, maybe it's not, but there's a lot more to damage than that meets the eye. The C post can also be pushed in, making that new door not line up at all.
I repair shit like this everyday. There's always hidden damage you can't see on the surface, and you need to be prepared and have the proper tools to make it right. At $6k plus parts, and a salvage title, I think you're in too deep.
ccapehartusarmyINF.(ret)
Gilbert AZ
NO WAY ive seen 03s 04s 4x4s and z71s for less then 5k not wrecked at all
and i also booked it in karpower thats kelly blue book software for cardealers and it only books for 7800 in that condition
---------- Post added at 12:14 AM ---------- Previous post was at 12:13 AM ----------
at least dont pay 6k for it ive seen same year tahoes with no damage cheaper
---------- Post added at 12:21 AM ---------- Previous post was at 12:14 AM ----------
7800 is the book in fair condition wich is a generous book i would consider that poor condition and ins adjuster doesnt use NADA they use the black book wich is used by finance companys flooring companys and such
M
maxamillion125
In my area the cheapest 04+ Tahoe LT was 9k and almost all of them have more then 130k miles. I still think at the very worse if I put 1k into fixing it up and keep it for 4-5 years when I sale it I'm not gonna loose big. Keep in mind I'm not trying to buy this Tahoe and flip it. I want a reliable, mechanically sound vehicle with 3rd row seating for my family. All the reviews I've read about the 2nd generation Tahoes are very positive.
Gilbert AZ
id be willing to bet by the time its all said and done the body shop bill will easily be 2500 to 3000 bucks
yer best bet since you seem hell bent on buying it go to the junk yard and see if you can find a undamaged rear quarter panel and passenger side door sand it primer it either have it painted or doit yourself then call a windshield place and find out how much the glass for the quarter panel costs because windshields and quater glass like that usually break when theyre removed
fiatdale
Houstons Best
Houston
Its a reliable vehicle no doubt. You're just going to have too much money in it. I can tell by your posts that we aren't going to sway you in the direction of not going thru with it, so let us know how it all works out. Speaking from a lot of experience on this topic.
Red Rider
I have a better idea. Buy this truck, then buy a second that has a good body but bad interior or something like that and make one good truck and sell the rest. If you have the time, you can part out the salvage truck and take what you need. You will come out ahead, and have extra parts, or can make some $$$ on what you don' t need.
Or just buy it and turn it into a wheeling truck. Leave body as is... but you still have to fight the title battle.
M
maxamillion125
The good doctor talked to his Insurance and they agreed to lower the buy back to 4k. I think its a no-brainer now guys!
M
maxamillion125
Still too much. Your choice, and you're going with it. Good luck.
Not sure what your problem is but I just don't see how you think this is a bad deal. Lets go over some of the facts.
Insurance estimated it was worth 12k
I'm buying it for 4k
I've already found the two passenger side doors in the same color for $850 total, I can install them.
I know the vehicles history and how it was treated, its mechanically sound
Immaculate interior
The only question mark is the quarter panel. Which I'm either going to leave as is, have a body shop do their best to make it look half decent for $500-800 or so. Or just replace it with a used one and paint it.
SRTH8R
Littleton, CO
He is just looking out for you and being realistic. The doors may be the same color but they won't match 100%. They would still need them painted and fender blended to do it right. Sounds like he does it for a living. $850 at a body shop won't go far. $1200 to repainted my rear bumper with no damage other than cosmetic on my TBSS. As far as I know you can't get full coverage insurance on a salvage vehicle. In the end it's what makes you happy. Sounds like you are set on doing it. So buy it and start a build tread already.
YukonXL04
The Riverboat
Arlington, TX
Insurance company said it was worth 12k before the wreck. Now with the salvaged title even when fixed properly you would be hard pressed to find someone willing to buy it for even 6k. That is where he is saying its not worth it financially...You cant compare its salvaged value to a clean title value....
However that doesn't mean you cant go for it.
SRTH8R $1200 to repaint your rear bumper!!!??? I had quotes around $400 from great body shops here to repaint my wife's TL rear bumper...
fiatdale
Houstons Best
Houston
Just trying to look out for you man. Ive done body work for more years than I want to admit. I know how these things turn out, and I fix and flip salvaged vehicles just like this. You're paying too much.
SRTH8R
Littleton, CO
1200 was what the body shop quoted to insurance when a little teeny bopper rear ended me stopped at a light. Red jewel tint coat is a pita to match, and I belive it's a 3 stage color. For $400 it kinda sounds like it would be repainted on the car. Could be wrong. 300-350 is what our lot rot bumper repair guys charge where I work. New pad, misc clips and labor. Fine by me I wasn't paying for it.
M
maxamillion125
I just called the DMV and if the vehicle is older then 5 years it gets branded as a totaled vehicle retained by the owner NOT a salvaged vehicle and I keep the original title. There is no salvaged title and the vehicle is perfectly legal to drive and there's no inspection or any other hoops to jump through. If I ever sell it all I have to do is let the person know that it's been branded as a totaled vehicle by the Insurance company.
NathanJax
Vacation Nathan
Jax, Fl
That's gonna be your problem... that's what others are trying to say.
Personally, if it's a vehicle your gonna keep and run in to the ground, and NOT worry about resale, I'd do it. However, if you ever go to sell it, it's not gonna be worth what you're gonna put in to it.
M
maxamillion125
I disagree if I show them the pics of how it looked when the Ins said it was totaled and also the Insurance estimate showing there was not any structural/frame damage. I don't see it being a big deal. Insurance companies total cars all the time for minor fender benders.
YukonXL04
The Riverboat
Arlington, TX
If I were buying a used vehicle that had been deemed totaled regardless of how well the repairs were, I would still want a significant discount
briannorris
