2015 Yukon HID Conversion from The Retrofit Source
twhitechurch
How can you connect canbus and relays???
Sent from my SM-N900V using Tapatalk
08grey
You only need to do one side. Plug the cancelor into light bulb harness then Into signal input on relay harness.
08grey
Make sure positive and negative are correctly lined up. Or POP.
S
Steve1081
Update: I am having an intermittent issue with the driver side bulb firing. I would recommend the relay harness to anyone doing this. I am going to email TRS and see what they recommend.
Tylus
South GA
Looks awesome. Can you update if the relay fixed the issue or if the Canbus is all you need?
S
Steve1081
I am still just running the Canbus with no relay. Both of the lights have been firing pretty reliably lately; but it still isn't 100%. Maybe 5% of the time one of the lights doesn't come on and you have to turn them on and off and then the light will fire.
If I was going to do it again I would go with a relay.
twhitechurch
I am using both relay and can bus and without the relay it was like 80% of the time it would not turn on
Tylus
South GA
Can you post a pic of the relay setup installed? I'd prefer to have a hidden install. The CanBus setup looks perfect for hiding wires. Not sure if that's as easily accomplished via the relay method
CDallasAtor
I would also like to see how that all works out with the can bus and the relay harness. Im having an intermittent issue with the drivers side as well
smittydog
updates/feedback?
so, it's been a few months now since you all have put in the HID's...how is everyone's morimoto kit? Any dislikes? lessons learned?
Would you do the kit over again? Would you do LED instead?
thanks,
Steve
twhitechurch
Love it, no issues with the canbus and HD relay set up. I had one small snafu but it was my fault because I disconnected the power when I was installing my cold air intake
Tylus
South GA
I'm willing to pull the trigger on some HID's, but I want to make sure I get any and all parts in 1 shot
Could you guys post up the part #'s and/or a direct link?
smittydog
high beams
Did anyone put in the high beams (HID) while they did the low beams?
How is the high beam pattern ?
Did you use the canbus and the relay (with the low beams)? (confused from earlier postings on this)
Thanks,
Steve
twhitechurch
I didn't do high beams because it takes a bit for the HIDS to warm up. I'm thinking I may out LEDS however
S
Steve1081
The only way HIDs work well for highbeams is with a bi xenon setup (single bulb for high and low). And that isn't plug and play on these trucks.
Led are going to be very weak output wise. You really need purpose built housings for LED to be bright enough for highbeams. I went with high output halogens from the retrofit source for highbeams and I am happy.
I installed the relay harness a few weeks ago and it was pretty easy. I now have the Canbus plugged into the factory headlight plugs at both headlights then one Canbus (drivers side) is connected to the on off signal on the relay harness (the passenger Canbus is not connected to anything).
The power for the relay is taken from the power block at the battery.
---------- Post added at 09:44 PM ---------- Previous post was at 09:35 PM ----------
There is a link in the 1st post of this thread. Get the relay harness and add Canbus connectors for H11 bulbs.
smittydog
Update from The RetroFit Source
I was getting ready to order from TRS and Charlie (chat rep) stated to use the MOPAR Low beam kit. (it has a capacitor in line that eliminates the flicker).
I'm ordering now....
Agent007
I just purchased a 2015 Tahoe LT and was curious if it is easy to upgrade the projector headlights for HID's? Do I need the conversion kit? I have noticed that the factory headlights are garbage and do not put off enough light on the roadway. Which brand would work best? Thanks all for your help!!
S
Steve1081
If you read this thread you will see what I have installed in my Yukon. Should be a similar process in your LT.
I would recommend the kits from TheRetrofitSource.com. Kits from DDM tuning will also get the job done for less money. But are not as high quality.
The only other tip would be to get a relay harness with the kit as opposed to trying to run it directly off the stock headlight cables.
smittydog
installed mopar low beam kit
Ok, i put in the low beam kit. The kit isn't long enough to put the relays in a good place (I will see if they have extensions).
I forgot to put the MAF sensor back on when starting the vehicle...the check engine light is now on. I am assuming that was the reason.
I put the 12v wire to the connector bus on top of the battery.
(could either of these make the CEL come on?) Check engine light
Now, I never checked this before, but when you turn on the high beams, do the low beams shut off? (low beams stay on when I turn on the high beams now).
Any ideas?
Thanks,
Brace
