Bomba02
There is no "streaching" it. If it was a mesh type material maybe. Plus it's powder coated. Need to find a Denali and measure the grille, might be closer to that size. Hard to see but this is held down and to the side, to much space to fill.
Sure it's not meant to fit with a little wiggle room all the way around to make it look right? Idk just a thought. I do have a denali with a denali grille if you want some measurements I could help help you out so you don't get beat up measuring a random truck lol.
SRTH8R
Littleton, CO
Lol, no it's nice and snug in the factory grille. I Evan thought about cutting it at the edge of the holes, but it is still loose. If that makes sence. If you want to take some measurements that would be great.
---------- Post added at 05:01 PM ---------- Previous post was at 04:57 PM ----------
I'm guessing 3 measurements would tell me if it was close. Just need inside measurements. Here is my artistic skills. Lol
Tahoewhat
Ballin' on a Budget
TX
You guys are funny... I would not beat him up looking at my grille. But then again, i have seen it already.
Mike - evidently from all the videos. lol
I thought this was SRTH8R thread. lol
YukonXL04
The Riverboat
Arlington, TX
At low rpm's my steering will catch when turning the wheel, is the intermediate shaft the problem?
Not sure what you mean by catch... But usually there is a clunk sound involved. Mine has it has well. One of these days I'll fix it lol
DCT
Too funny. This is one of the easiest fixes. The clunk on my burb was non stop driving me crazy.
---------- Post added at 06:16 PM ---------- Previous post was at 06:14 PM ----------
It acually grabs the wheel for a second or two, its fine at upper speeds..
Probably power steering pump is turning to slow at low engine rpm so you lose pressure. Just keep a little more rpm on those slow full lock turns.
chevync
North Carolina
Idle is a little low, once I get a few hundred more miles on the newly rebuilt engine i'm taking it and having a tune put on it so they will check timing etc..
Bomba02
Measurement A. 38 3/4
Measurement B. 37 1/8
Measurement C. 9 1/4
There is a 1/4 gab in between the honey comb grille and the out like of the grille. The honey comb grille measurement are
Measurement A. 38 3/8
Measurement B. 36 1/2
Measurement C. 8 1/2
Hopefully those measurements can help you out.
SRTH8R
Littleton, CO
Thanks Billy, that helps a lot. I think I will order the Denali speed grille. Should be a nice fit. Worst case I will be selling one of those at a discounted price. Lol.
Bomba02
Glad I could help man.
Mister H12
Undercover Racecar
West Tennessee
Working on my leather seat swap, did a google search for seats.. found this. Lol
02 Burb
California
Changed out the old, cracked front sway bar end links with moog. Took about an hour and all from start to finish.
Yuko04
"SquareBODluvr"
MN
Washed her and put it on the lift. Gonna change out wheel bearings and power steering pump.
Well when I get back Friday evening.
SUBLETTKUSTOMZ
Drewphil
