2008 Yukon XL SLT--Service Traction Control/Stability and ABS
HeavyXL
Atlanta
Ok guys, got a really strange issue that cropped up today after I had the dealer rotate and balance my wheels.
So prior to having this standard rotate/balance I had no service lights or abs issues. No more than 2 miles down the road after my rotation, I come to a stop light and the service traction control, service stability control and ABS lights come on. I drive about another 1/2 mile stop, cycle thru the info cluster and also notice the dealership failed to reset my tire locations...so I turn around and head back. Since i figure the dealer will take awhile I make a pit-stop to grab some food. The service lights went out once i restarted the truck, however they came back on just before I pulled into the service.
Service manager shakes his head about not resetting the codes, but is puzzled about the service lights.
Service tech pulls the truck back into the shop resets the tire locations, and pulls the codes. I'm told it's some sort of low voltage error which is causing the service lights and ABS problems; however since it's the weekend the dealer wasn't able to dig any deeper.
So, has anyone had this occur? How could a simple wheel rotation end up with service lights and ABS issues?
This evening I have driven the truck and noticed there seems to be no rhyme or reason as to when the service lights appear, but sure as taxes the lights come on during short or longer drives.
Here are a few particulars about my truck:
2008 Yukon XL SLT
Momo 24" Wheels
Brakes where replaced all the way around two months ago
Mileage: 120,3xx
Dealer maintained truck
Any help or direction would be greatly appreciated!
Thanks,
Marshall
08grey
Check autoride links see if one popped off
SRTH8R
Littleton, CO
Sounds like a possible wheel speed sensor going bad to me. Not for sure but you have to buy the whole hub assembly to get it most the time. Dealer will be able to put the scanner on it to see which wheel has a code stored. Of corse they will want a diag fee. Not sure if auto zone or somewhere has a good enough scanner to read those kind of codes.
rroadkilll
Kodiak Alaska
Had the same issue after installing new tires...
But mine was after about 1000 miles... and only happens when I come to a stop. And has onlybhappened about 4 times now....
I'm likeing the low voltage thing! Just before my trip I ran the Battery dead, so...
greenmax
when i did my rear shocks i somehow unplugged the rear wheel sensor, plugged it back in and its fine, check the connectors
HeavyXL
HeavyXL
Atlanta
Still getting warning lights randomly : (
Hey, I found a service bulletin and wonder if anyone has any intel to support this being directly related.
I have not been able to see a root cause or solution in this bulletin. Has anyone else seen this bulletin?
Service Bulletin No.: PIT-5120-A
Component(s): ELECTRONIC STABILITY CONTROL , TRACTION CONTROL SYSTEM
NHTSA ID Number: 10047479
All Products Associated with this Service Bulletin close
Vehicle MakeModelModel Year(s)
CADILLACESCALADE2007-2011
CADILLACESCALADE ESV2007-2012
CADILLACESCALADE EXT2007-2012
CADILLACESCALADE HYBRID2008-2012
CHEVROLETAVALANCHE2007-2013
CHEVROLETSILVERADO2007-2013
CHEVROLETSUBURBAN2007-2012
CHEVROLETTAHOE2007-2012
GMCENVOY DENALI2007
GMCSIERRA2007-2013
GMCSIERRA DENALI2008-2012
GMCYUKON2007-2013
GMCYUKON DENALI2007-2012
GMCYUKON DENALI XL2007-2012
GMCYUKON HYBRID2008-2009
GMCYUKON XL2007-2013
GMCYUKON XL 15002007-2012
GMCYUKON XL 25002007-2011
Details close
0 Associated Documents
Manufacturer: General Motors LLC
SUMMARY:
GMC/CHEVROLET/CADILLAC: INSTRUMENT PANEL MESSAGES REGARDING STABILITRAK MESSAGE, TRACTION CONTROL MESSAGE, SERVICE BRAKE SYSTEM MESSAGE, IS OFF AND GAUGES, IN VARIOUS MODULES LOW SPEED SETTINGS, ARE INOPERATIVE. MODELS 2007-13 ALL ESCALADES; AVALANCHE, SILVERADO, SUBURBAN, TAHOE; SIERRA, ALL YUKONS AND DENALIS. *PE
Bad324
I'm experiencing the same thing and wondering what is going on with it
Rabbi
2008 Yukon XL SLT
Momo 24" Wheels
Mileage: 120,3xx
Thanks,
Marshall
Rabbi
service traction control, service stability control and ABS lights on:
I recently had my rear air shocks replaced with a set from Arnott. When I got I the 2008 Yukon Denali to leave, the service traction control, service stability control and ABS lights were on. My mechanic tried pulling the codes from the truck, but his diagnostic tool kept locking up with a communication error. I went home and did some research. A quick call to Arnott tech support and they immediately diagnosed the problem as a disconnected ABS / tire position control wire. Makes perfect sense, when I think about it.
Coming off the back of the axle, just to the inside the wheel housing, is a wire that goes through a couple of blue wire holders (NOT connectors) and then heads up under the bed, just above the shock absorber on each side. BOTH of my connectors were unplugged. The passenger side connector was viewable after taking the spare tire off. Look through the cross member frame hole from the back. The Driver's side connector is impossible to see without mirrors, and we could only get one hand on it (by feel) to re-connect it. Put your hand above the cross member from the front to get to it. Both connectors are blue.
We then had to clear the computer codes twice before the error messages went away. They have not reappeared since. The placement of these connectors is STUPID. GMC designers must have never thought about anyone having to get to them. Or that mechanics working on the springs or shocks were likely to pull on these wires hard enough to unplug them.
I don't know why a tire rotation/change would affect these wires, but it sure would be a strange coincidence. If one of these wires was cut or broken internally, I suspect that it would throw the same codes.
Good luck!
scottd
