I am planning on going by the oil life monitor. I put 200k miles on my Honda Ridgeline, which uses a similar monitor and similar math to decide when you need to do your oil change. I would send an oil sample off every year, and everything always came back good.
I believe that the monitor is based on a good quality Dino oil, so if you are running a high quality synthetic you should be even better. I would also assume that if you're vehicle is made after the Dexos requirement came out, that would be factored into the math in the oil life monitor.
I run Amsoil, so I am interested in how it will hold up vs the monitor. I will send off a sample and share it when I drain the oil that is in it after the oil that is in it now. The Yukon had 120k miles on it when I bought it, and I just put Amsoil in it for the first time. I don't think it would be fair to do a sample on this drain interval because I have no idea what oil has been run in it, and I am sure that it will clean some varnish off on the first run.
I will share the report when I do it.
