nimrod.sixty9
Hold on, I got this.
Was easier to just swap throttle bodies. Noise stayed and issue stayed with Yukon. Had to call it quits before I could do another round of testing spark due to millions of blood sucking mosquitoes. Another day...
either the crank sensor was not putting out signal as needed because of fault or power supply issue, pcm was not functioning correctly, icm is faulting in the same way as sensor or the coil is screwy or maybe even a ground issue somewhere.
supposed to be able to start with a bum cam sensor but i code would post about it. power supply as in the wiring and fuse that supplies the crank sensor with power could be goofed somewhere. the pink wire on either cam or crank sensor should supply system voltage during run and start. crank fused thru ecm-1 cam fused thru eng-1. both under the hood. pcm receives three voltage feeds. constant hot on pcm "clear" connector pin 21 orange wire. hot in run and start "black" connector pin 18 pink wire. hot in run only "black" pin 13 brown wire. fed from ecm-b, ecm-1 and #18 brake fuses respectively. use gf for help probing as needed. unlike other pcm's the factory does not give a list of what can happen when a certain wire into the pcm is dead.
hmm, does tranny indicator still light? if not check "trans" fuse in the cab. if no system voltage on either of the fuses contacts there is a feed problem from the ignition switch perhaps or further back. however if it does actually crank then the power supply to the switch should be good and the switch itself might be at fault. those last couple of circuits are fused separately outbound of switch but fed inbound to switch with only one wire. take a moment and soak it in. now start probing.
gear selection indicator foo.
switch actually has two inputs and five outputs. just the ones i mentioned just happen to branch off the same input line.
the power to pcm can be tested with the pcm connectors off and tun the key as needed to check the power voltage the sensor ones can be tested at sensor connectors.
so looking at the video again it does not seem to be tied to fuel flow after all. it can only be the iac that is doing it as it is the only servo device around there engine with the exception of egr. if i recall correctly mine does the same. part in oe. i have a spare because i believed that it is faulting and choking the engine and won't let it start every few weeks. strange part is when it happens i have to turn key off and literally open and close my door. i am looking into the issue which started after the 0411 pcm upgrade. i am not fully equipment enough just yet to get fast data or easy answers and i know the program on it has some altered specs that are really messing up tranny shift when i floor it while already moving a bit. i thought it would be the iac doing it but when running it seems to react as it should and quickly as well. i had a one time egr fault qwerk that never came back before he pcm change and for some reason the fuel input got so bad i would be sometimes at 8mpg till i shut down. would floor it and make it look it was puffing diesel smoke particles. could restart and then maybe 15mpg say 30 minutes later. only happened once on on trip to come home. am looking into several other things tied to it. seem to be normal since then. have not touch the egr as it seems to be working correctly now. until i equip myself enough i think i am looking at a power supply issue somewhere myself. i have a fluke 289 with a gazillion probes and infrared thermos but still do not have a fast enough laptop to get 4 samples per second of the entire data output of pcm at the same time. instead it can one sample every three seconds. it is really making it difficult right now to catch a intermittent data glitch.
do what you can and let me know what happens. i will stop rambling till the next post.
that only other device that can make a noise like that is possibly the egr. it is also servo drive type. every other sensor is not motor driven. you want to try the egr?
i have a laptop built in 2005. so much stuff i want to buy and that keeps being put off because i can't afford the $2100 hp i want. when back at work will hit up the pawn shops again to find some temp solution.
if the egr is open it technically is open from intake to exhaust and can thin out the mix so to speak. remove it but leave it plugged in and see how it is working when ignition is on/off. clean it as well.
so has spark and if was consistent during the crank and not start then it seems the crank crank cam sensors are working. and if you had fuel pressure it has to a really out of whack mixture ratio or the actual injectors are not firing. the passlock would not be a cause because it would kill the fuel pump relay just after starting. does wiggling the fuses in the engine fuse box make any difference? pm me your email, i have a sheet or two of troubleshooting no-starts.
warrants a visual inspection. at worst you may just have to change the gear which is straight forward but have some roll pin punches handy. if you are up to doing the inspection grab some pics as well please.maybe a bit to much. i can get movement on a new dizzy but yourswarrants a visual inspection. at worst you may just have to change the gear which is straight forward but have some roll pin punches handy. if you are up to doing the inspection grab some pics as well please.
---------- Post added at 02:48 PM ---------- Previous post was at 02:23 PM ----------
oh and a little upwards movement is not really bad. as the engine runs the angle of gears pushes it up slightly as the rotor turns clockwise.
