I officially think
qukon 95
I think my rear end has a problem it feels like something is shifting when I punch the pedal
Or if I have people sitting in the back it does it with normal stop and go.I have no noise from the rear
The u joints are new it seems like it's the limited slip acting up.:hmmm2
qukon 95
qukon 95
I had my nephew to hold the brakes & give it gas I didn't see any thing
Shifting but there is a lot of play when he let off the gas and then give it gas in the rotation it's not ujoints I did hear a little clicking in the transfer case I might have 2 things
Going bad transfer and the limited slip thingy in the rear.
qukon 95
qukon 95
Yes didn't see anything moving excessive .I guess I'll pull diff cover to check limited slip.
This is a rebuilt rear end and original transfer and it does give a clunk noise sometimes when it's in park to drive like when you park on a hill it happens on level ground to.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
given it is a 4wd unit you will probably always have a decent clunk as there are lots of gear meshes to go thru from tranny to rear end. gets cumulatively worse with wear in the different parts. could see if the t-case output yoke might need to get its splines greased up to see if the issue is reduced.
qukon 95
qukon 95
That already been done with no improvement.the play is 1/2
autolover3
Bismarck/Wahpeton, ND
There was a TSB with a updated nickel plated slip yoke or somethin that was suppose to fix acceleration from a stop clunk. Damn thing is expensive though. I just greased mine good.
qukon 95
qukon 95
Well after changing spider gears it did fix the clunk when putting in gear but still has this
The shif feeling in the rear Sunday I looked under the rear again and the sway bar has play
In it I need to put all new bushings on and see if this solves the problem
Donnie Yukonie
Yates Caretaker
Not that it matters for me anymore but do you have the TSB code?
2000tahoeZ71
Get underneath it and grab the driveshaft where it enters the rear end. Push it up and down and see if there is any play in the pinion bearing. My truck had kinda the same things going on and I caught it too late after the pinion bearing failed and ate my ring gear.
qukon 95
qukon 95
yhea i did that no play in it but i will see if it's the rear sway bar bushings.
dizhai
