L.E.D. Bulb Conversion/Cross Reference List
Cadyman68
Hey guys, im having a problem with mine. I have an 04' denali and i replaced mine with the leds as well and they wont come on when i open the doors or the fob but the ones on the doors come on just fine. tried putting the original bulbs back in and stil nothing. but the ones up front can be switched on with the buttons. same with the rear ones as well. can anyone help me figure out this problem and save me some money by not going to the dealer for help!!!? thanx
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
you need to press your overhead button on your headlight switch
Cadyman68
I already did that. Not the issue.
JesusArTorres
Tulsa, OK
What about reverse lights? What's a good, bright LED for that?
I hate not being able to see anything when reversing in the dark.
02 Burb
California
Here is what i got i wanted a white led bulb but not be worse than halogen and so when i got these there was a noticeable difference and plenty bright with the projector in it. A back up camera though is what really made a difference when backing up at night.
JesusArTorres
Tulsa, OK
I'll check 'em out, thanks. Do these just plug in out of the box? I have an 03 Yukon.
Did you have any problems with them?
02 Burb
California
Yep plug and play (leds are polarized so if they dont work, just flip it) and for 15 bucks i thought what the hell. No problems at all with them, i even got leds from that seller for my fogs.
JesusArTorres
Tulsa, OK
If you're ordering from superbrightleds.com use code "Pirate14" for 10% off. I don't know when it expires...
cmyhre85355
Arizona
Ordered some map lights from SuperbrightLeds the other day. They fit a bit oddly but I was able to get them in. Heres the issue im now having though. Driving home last night I had no dash lights at all. Pulled the LEDs in the second row and now all is well. The bulbs I ordered are all CANBUS bulbs. Could that be the culprit? Update- it seems that pressing any of the overhead buttons will toggle the instrument/dash lights on and off. Im a bit baffled at this point.
Sent from my SGH-T999L using Tapatalk
jose6326
Chicago
I have an 03 Tahoe and im deciding if I should replace the cluster bulbs since some of the originals are burned out or swapping the cluster with an escalade cluster
can someone tell me what LEDs I need to replace the ones in my 03 Tahoe?
and where is the best place to buy at a good price
I seen a kit on ebay which includes the stepper motors but I don't think I need those
any suggestions
thanks
JesusArTorres
Tulsa, OK
any suggestions
thanks
x2
YukonXL04
The Riverboat
Arlington, TX
Correct, however it does specify the size. From there you can either google, amazon, or ebay to find the best deal.
Not trying to be rude, just trying to help
Tupapi
