03 dash bezel in 2000 dash
benztrk
Central FL.
2000 dash+++ FINALLY DONE++++
Has anyone done this conversion to retro a DD? If so, how did you relocate HVAC controls to fit newer bezel? I have a 03 cage, just need to relocate HVAC controls. Any pics of the relocate would help..... thanks in advance.
B
benztrk
Central FL.
I got pretty lucky, in the fact that my brother has a 2004 Tahoe, and I pulled his bezel out and popped it in my last night. Everything fits. The Ash tray and 12V outlet door need to be modded a little, but I have to paint the bezel anyways. My dash is a light brown color, that doesn't come in the 03 and newer bezels. The only thing I still have to figure out is how to move HVAC controls down about 1/2" or so. Hope to get a bezel in the next day or so to start working with.
lowAZhoe
Resident GM Tech
Phoenix, AZ
i just did mine. no pics of it. but its pretty easy. i removed the cage and slotted the holes with a round file so it would go down. and also cut the clips off the hvac unit and instead slotted the holes on that and used screw to hold it in. then used a dash kit for a 07-09 tahoe, cut the mounts off of it and made brackets out of metal strapping that bolt to the side of the deck, and also a piece screwed to the back to make it harder to steal and helps stabilize it in the dash. i didnt mess with the ashtray or power outlet door...i dont need ashtray and i can still plug stuff into the power outlet if i need to. took about an hour to get everything fitting right.
B
benztrk
Central FL.
Sweet. That's what I was thinking after pulling my brothers apart. Just cut off the pins and use the screw holes instead. Why didn't you just use a 2003+ dash kit? After changing the cage and bezel, isn't it the same as installing it in a 03+????
Mr45
Florida
OK fellas, you know the drill. Need pics of said swaps, or it didn't happen. :)
lowAZhoe
Resident GM Tech
Phoenix, AZ
i didnt change the cage. i moved the cage down. ill take some pics of it installed.
---------- Post added at 04:36 PM ---------- Previous post was at 04:34 PM ----------
also i work at chevy and got the bezel for about $110 including tax. a few days later i found one laying around and gave it to a guy that doin the same thing in his silverado.
lowAZhoe
Resident GM Tech
Phoenix, AZ
friend used a 03+ cage on his over the weekend and still had to hack it up. use the cage you have and it will look better...
B
benztrk
Central FL.
Finally got time to complete to DD install in my 2000 yukon with the 2004 bezel......
[/IMG]
[/IMG]
[/IMG]
---------- Post added at 06:15 PM ---------- Previous post was at 06:01 PM ----------
ttt
B
benztrk
Central FL.
Nice job, I'm glad to see that cage went to good use.
Yeah, thanks again for the cage. Worked perfect.
Thanks guys, I love the way it turned out. Haven't decided on the color yet. Kind of like the two tone with the gray bezel...... what do you think????
Bighomie_83
Question, could one use the HVAC unit from a newer Tahoe?
---------- Post added at 11:53 AM ---------- Previous post was at 11:44 AM ----------
Also will a2003 silverado Bezel work? Junk yard near me has two that are totaled out pretty much anything tastes not seats suspension engine or transmission related can bee picked over for under 20 bucks
sparks
Tampa, FL
it looks like the newer dash bezel hangs lower than the origional, does it interfere with anything? is it noticable?
im looking at doing this conversion to my 02 denali, but im worried that the 03+ dash bezel will hang too low and not fit right with the console.
Conedaddy
