2/4 drop and 24's done now trac light when turning
Turboedsupe
So got my 2" spindle drop and 4" coil drop on. Also got 24x10 with 305/35 tires. Now when I turn and am on the brakes sometimes the traction control light comes on and abs activates. Also even when turning while on the gas the light will come on sometimes. It still does it with traction control deactivated. This is my family wagon so I need to make sure its driving perfect for the wifey. I wasn't sure of the cause I read it might need the ebcm recalibrated but of course the dealer has no idea on if that's the cause or even possible to do
Bruizza
I have the same issue only my abs has never kicked in. I did a 2/3 on 26s with 305/30 tires. Just noticed today the tire is rubbing some arm that attaches to the hub. At least I think it attaches to it. Didn't inspect it closely yet.
NathanJax
Vacation Nathan
Jax, Fl
I bet a connection on top of the frame rail near your a arms was bumped and disconnected or came loose.
T
Turboedsupe
Rwd, 2 wheel drive. I'll check the connector but like I said it only does it in turns.
HUMBL57
AC Guru
Phoenix, AZ
Everything seem ok near your front hubs and abs sensors when you swapped the spindles?
T
Turboedsupe
Yeah everything seemed fine. The Tahoe only has 45k miles on it. Everything was real clean and I kept it that way on the install.
NORCAL SS
SUV SUSPENSION GURU
is it a 2007 model?
Also which spindles used?
NORCAL SS
SUV SUSPENSION GURU
yeah normal on the 2007 ill try to find the thread i posted on this a while back
T
Turboedsupe
Normal huh well that's crappy. I really wanted to get this worked out. Can anything be done to fix it. I looked all over and can't find a thread mentioning a problem like mine
NathanJax
Vacation Nathan
Jax, Fl
T
Turboedsupe
Yeah I read a couple of those threads and was just hoping someone had actually found a solution for this.
07 Tahoe
I pretty much have all the same issues on my Tahoe and it is an 07. I have the Ground Force 9856 kit with 26's. Tire size is 305/30/26. Any fixes yet?
Durobans
