5.3L Starting Issue
SGinn722
Memphis
I have an 08' Yukon with the 5.3L. Within the last 6 months or so my truck has begun to act as if the motor doesn't want to fire when the starter turns over. It usually always does crank but sometimes the starter has to turn for a good while before the motor cranks. Other times the starter barely turns and the motor bogs down and barely cranks. Once it's running it runs perfectly so I don't think it's an issue with plugs/wires/coils. I replaced the starter but wound up wasting my money when it didn't fix the problem. I've heard of others having similar issues but has anyone definitively found what the problem is? It's more annoying than anything else. Never used to do it.
Physh1
Sounds fuel related, especially if there is no SES light. Try changing your fuel filter...if that doesn't help your pump may be failing but, ideally, you'll want to do a fuel pressure check.
Cameron
SBCT
Battery
Sent from my XT1080 using Tapatalk
SGinn722
SGinn722
Memphis
I had it in my head to start simple with the filter. I'll change it and see what happens. If that doesn't work I'll have to take it to my mechanic. I've had the electrical system tested and everything checks out. Battery is strong and holding voltage. Thanks,
SBCT
Definitely sounds like a possible amperage problem with your battery.
GM Customer Service
Michigan
SGinn722,
I am sorry to learn that you are experiencing an issue with your vehicle. I understand that you are seeking advice on how to resolve this vehicle concern yourself and I cannot give any technical advice. However, I would like to look into this concern for you. Could you private message me referencing this thread including your full name, address, phone number, VIN, current mileage, and preferred dealership?
Jennifer T.
GM Customer Care
SGinn722
SGinn722
Memphis
Thanks for the help. Hopefully I'll get it figured out without draining my bank account.
SGinn722
SGinn722
Memphis
Back to this again....The starting issue only occurs in warmer weather, especially when the motor is warm. If I give it a little gas it cranks somewhat normally. Otherwise, it turns over and over and doesn't catch for a while. I've replaced the battery and the starter so I know it isn't that. I guess I'm confused as to why it would be a fuel pump going bad if it runs perfect once started. I've read of a similar issue with a nbs Tahoe where the guy had to replace a coolant sensor that was causing startup issues? Can anyone help?
CrashTestDummy
Pearland, Texas
Without a gauge, you're guessing on the problem. One quick, although not complete test is to:
1. turn the key to on, but not start. Wait about 5 seconds.
2. turn key off.
3. turn key on, but not start. Wait 5 seconds.
3. turn key off.
4. Try to start truck.
If it starts, I'd bet it's a bad pump or clogged filter. But again, for a better verification, get a fuel pressure gauge and see what kind of start pressure you have.
GM Customer Service
Michigan
Hi SGinn722,
I’m sorry to hear of this repeat concern with your vehicle. I cannot guarantee anything, but I will be glad to look further into this concern. I see that you have spoken with us before regarding this concern and we can be reached via private message if we can be of any assistance. I look forward to hear from you!
Kristen A.
GM Customer Care
ChrisK7UND
Let me know what you find out. Mine has also done this for no reason. Also, I always have to pay a "diagnostic fee" at the dealer to get it looked at.
Chris Underwood
SGinn722
SGinn722
Memphis
Turns out it's the fuel pump....Does anyone know the AC Delco part number? There appears to be several options. Mine is Vehicle VIN 0
GM Customer Service
Michigan
Hi SGinn722,
We'd be happy to locate a part number for you. If you'd like our assistance please send us a private message with your VIN. We look forward to assisting you.
Thank you,
Andraya R.
GM Customer Care
scottd
