Alternator?
Sam Hamm
can an alternator be rebuilt to put out a higher ampage or not?
and what is a good place to get high output ones other than iraggi?
whitetahoe
yeah it can be rewound to get more amperage. but you can try DCPOWER ALTERNATORS, MECHMAN ALTERNATORS. and there is a guy that is from somewhere in alabama, his company's name is EXCESSIVE AMPERAGE 13347129955. if you google all three, im sure one of them can help you
ROBERTOcritser
Kentucky
I went to a few local generator shops that can do alternators and they both gave me an estimate of around $400 to rebuild my alternator and upgrade some other stuff with it. and that would give it an output of 200 amps. so to answer you question, Yes and i would try local shops if you can.
blueflamed03
Oklahoma
search first, because I know soemtimes you can buy one ready to bolt on cheaper than building one. Excessive, Iraggi, but I prefer Powermaster myself.
You can order a ** Powermaster from Jegs.
Modded
That Guy
They must be trying to pull a fast one on you.
I saw some on Ebay for my 07 the other day for less than than, high output and meant for very powerful systems.
JennaBear
Resident Ninja
San Diego, CA
We have a friend that works at an alternator shop, I can not for the life of me remember the name!! I will have to ask Justin but I know they have an online store, and you can get 250amp polished alternators for $300.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
yeah, that IS the problem with higher output units in standard cases.
the 145 amp alternator (KG3) is one hell of a large alternator already though.
145 x 14.4 = 2 kilowatts.
Young28
The Yukon God
ga
it was out of warrenty so they were going to charge me the price of a new one to fix it. I needed one that same day so i just got a power master from summit that same day. (they are like 20 minutes away from my house) Havent had any problems with it. Then again i have not driven the truck in 4 ish months.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
keep in mind that many of these ** alts require a higher idle engine speed to charge...thus possibly needing some pcm changes.
S
Sam Hamm
thanks for all the help guys. i may try excessive since im in alabama.
and eagle, give me some more info on this. i have been reading some stuff about it but dont really understand whats the difference in a standard case and i guess you would say modded one.
and i have heard ohio and iraqqi are good but if i could just get mine rebuilt i would do this but if its more than 300$ i will just buy a new one.
---------- Post added at 10:33 AM ---------- Previous post was at 10:32 AM ----------
and girls
briannorris
