Extra battery or Replace Battery (need help)
ROBERTOcritser
Kentucky
I have a JL Audio 1000/1 v1 amp powering a 12W7 in H.O. Box. I am getting a lot of voltage drop on my dash meter which of course makes my lights dim and is expected with such a large amp. I need to stop this voltage drop for 2 reasons. Stop lights dimming and my amp gets hot quickly. My local car audio store suggests a 2nd battery to power the amp with a relay but many people I talk to who have car stereo systems say I should just get a yellow top optima to replace my main battery.... What should I do and why? I also plan on putting another amp in for my high's (JL 300/2) The store I go to wants to sell me a Stinger SP1000 DryCell Battery. but I know there are other good batteries but if I buy their stuff they are more likely to help if something goes wrong.
Stinger SP1000 with relay from car audio store = $380 or so
Yellow Top Optima from local auto parts stores ~$210
What should I do? If you have any other questions about my system please ask.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
turn the gain down, turn the bass boost down (ie more gain) and turn the bss eq (ie another gain) down.
with the stock alternator you should not be having any issues with such a small amp.
maybe try using a DMM to check that your gains are at least ball park?
edit: you have an 02, that one has the smaller alternator right?
might be a good time to upgrade the ALTERNATOR, since yours might be on its way out anyway.
Amps run on the alternator... NOT the battery. Battery has practically nothing to do with the 'stereo', so I am unsure where the whole internet "dimming = spend $300 on batteries and capacitors" thing came from, but it is wrong.
It's kinda like saying, "I can't lift this heavy object, so instead of getting someone stronger to do it, I'll put on a pair of Nike Air 360".
ROBERTOcritser
ROBERTOcritser
Kentucky
I've talked to the guys at the audio store and they've seen my setup before and they turned all my boosts off and my gain is at half and it still pulls like a mother and there is no way I'm turnin my gain down b/c what's the point if it's not as loud as I want it to be? what do you mean by DMM?
ROBERTOcritser
ROBERTOcritser
Kentucky
my alternator is the 130 or 135 amp. im not sure exactly but im sure you know which one it is. It doesnt appear to be in bad shape. If I did want another alternator for higher output, where can I get one?
Eagle
EL PASO, TX
an extra battery is jsut an additional load, and would only
a: EXTEND key off playing time, or
B: be a reserve STARTING battery.
Neither does ANYTHING about dimming or pulsing lights.
a 130 amp alternator is PLENTY for a 1000/1.
1000/ 14.4 = 70 amps... at maximum output.
you are probably averaging less than 35 on music.
I htink you are looking at this from the wrong perspective///
I know you said your gain is at half, but *WHY* is it at 1/2?
I've known some that needed the gain as low as 1/4 or less to make rated output.
in these situations most common complaints were:
1: caused a lot of wasted power consumption ie dimming/pulsing problems
2: caused overheating problems
3: not really made it all that much louder
Do 1 and 2 sound familiar?
if you turn it down 2-3 numbers, (or just enough to be barely noticeable), do the problems go away?
t all depends on the input voltage you provide the amp, the gain is there to match the amp to the input voltage, not to control the volume/loudness of it.
you can use gain to make something quieter, but you can NOT use gain control to make it louder.
ROBERTOcritser
ROBERTOcritser
Kentucky
(I just feel like I need to say this) The "gain" on JL's are actualy called input sensitivity and there are no clicks on them just a flat head turn knob with no individual points. but I know its the same thing. Ok Eagle you make a good point and YES on number 2 it gets hot too quickly for my taste but it has never shut off. Ill try start turnin my gain down and see where it stops makin my lights dim.
---------- Post added at 07:23 PM ---------- Previous post was at 06:35 PM ----------
ok i just went for a lil test drive and I was turnin the gain up and down and the only time it didnt dim my lights at all was when it was practically all the way down but I did not see a big difference when turning it down just a lil bit. It was basically even - as I turned down the gain, the lights would dim less. as the gain increases, the lights dim with it but there was no spike in how much the lights dimmed.
tahoe02
i have the same problem with my 3 earthquake 12"s, i was told to install a second alternator and that would solve my problem. Does that sound correct to everyone ?
G35 2007
that's weird I used to run 2 L7's with a capacitor and a reg battery and a 1500 amp way more then I needed to but I never had any dimming problems.
Eagle
EL PASO, TX
What you said was "i have 20's and they told me to install an 8.1"
HUH? what is the problem? and what do the size or brand of speakers have to do with the problem?
have you tried a LARGER and better quality amp with more onboard capacitance, better wiring, checking voltage drop (particularly across a non ANL fuse, or screw type connectors), checking the ground?
Have you DMM'd or `scoped the outputs to make sure you are not driving overdriving the amp into clipping?
I usually see this 'dimming' issue with people with too small of an amp... not too large of one. Or people who can't hear distortion, and think that overdriving the equipment is what it is supposed to sound like... Boom boom/ 'kickin hard' = bad bad.
130 amp alternators or better are more than ample for anything short of a pair of strapped 1200.1s, or something in the 2000w+ RMS range....
And the easiest fix for that issue in daily use is to turn the volume knob left to drop 3dbs and require 1/2 the power. If you still have issues, your amp is crap or your settings/install are.If it isn't loud enough when set correctly, get better subs and/or a bigger amp.
You should not be driving around with your stereo that loud anyway, strictly for health and personal safety reasons, much less the disturbing the peace issue.
:hands:
tahoe02
i dont know exacly what the specs are on my amp but when i bought it the guy assured me it would push the 3 12"s maybe ill try turning down the gain or messing around with the settings
---------- Post added at 11:15 AM ---------- Previous post was at 11:12 AM ----------
i dont have a capacitor, i might need to get one of those also.
ROBERTOcritser
ROBERTOcritser
Kentucky
so I found out the deal on this Stinger "battery". Its not really a battery but more like a capacitor but more like 50 capacitors cuz it can charge and discharge in like milliseconds or something and it can hold way more power than a capacitor so it would be able to give my amp the extra power instead of drawing it straight from the alternator... does this make any sense?
DarkTahoe00
IN
I ran second batt in mine its a Kinetic one the best on the market and had no problems. and I got a the same amp as you and a 300/4 JL amp.
Eagle
EL PASO, TX
sure, makes perfect sense.
marketing mumbo jumbo and fake technospeak sells products... use it.
battery 12.8v
alternator 14.4
dimming = less than 14 v
to use battery, voltage must fall to <12.8 v...
ROBERTOcritser
ROBERTOcritser
Kentucky
battery 12.8v
alternator 14.4
Why do you sound like your gettin pissed at everyone on this thread? I mean, if what these car audio store guys are sayin is wrong, then why do they continue to sell them cuz if they didnt work then people would eventually stop buying them regardless of what the salesmen tell them. and as darktahoe said, he has more watts than me and he put a battery in and it helped. and you really havent given any advice on what I should actually DO. all youve really done is bashed people on what theyve posted.
Robert.K
San Diego, Ca
if you go to the kinetic website, there is a link to a power cell calculator for your wattage. put the amount of wattage you wish to run( or are running), and its does the rest. I plan on running two 2500 memphis amps powering two Memphis mojo 15 QVC's and I need like 4 batteries. and I called the memphis place for advice on installation and the went to my truck and told me what I needed to do. Just a suggestion. and also have you done the big three upgrade?
ROBERTOcritser
ROBERTOcritser
Kentucky
what is the big 3 upgrade exactly? I think I may have done one part but what it is first?
and I've been to the Kinetik site and done the calculator but the price would be about the same to buy from the place Ive been goin to plus they are more likely to do somethin if I buy from them and its ***** up somehow. and if you get that system its gunna be nuckin futs dude.
Eagle
EL PASO, TX
Dude: as for your assertion that if it were wrong people would wise up...may I point out audiobahn, dual,DHD, American BASS, rockwood, pyramid, "1000w" amps that are huge heatsinks with mosfets maybe capable of 40w peak... Dynabatts that are Stinger batteries that are actually Hunter batteries... '1000W!!!!!' amps with 30 amp fusing ;). You;ve all run across products that sell to the uninitiated and make you go WTF
DC is DC fellows.
1: I've given you PLENTY of advice... turning off eq and bassboost, and turning down the amp from unknown gain setting to unknown -unknown gain setting.
you stated flat out that if I suggested anything that would make it less loud you wouldnt do it, so I assumed you were uninterested in determining the casue of the problem and resolving it.
Have you DMM'd your amp to determine that the gain is set at least close to get teh power output required? Have you tried another amplifier preferably one with a known beefy power supply?? Which type of 'dimming' are you experiencing?
For someone with a technical problem you are short on details and short on follow thru... Sorry if I am blunt, but my time is very valuable.
As to why it sounds like i am pissed off, I wasn;t until now.
I am brisk, especially when I am engaged in my own research but will stop for a couple of minutes to offer a shove in the right direction. I try to lead you to the answer so you will learn something and be able to defend yourself against "he said" as opposed to 'but this other guy said'.
SO>>>
www.bcae1.com -simplest and most correct NooB site i ever found for explaining to someone why 'the salesman said' is wrong.
If my neighbor can understand it, you can.
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
As to why car audio sales guys say this that or the other etc etc. I can only speak to my experiences over the last 15+ years but:
A: because people would rather throw money at the problem than admit they made a mistake in product selection, install, etc... or that their salesperson was wrong. This means they have failed to discern trustworthiness correctly. They WANT to buy product to fix it so they don;t feel like they screwed up and a salesman's job is to sell a solution, preferably one that puts money in his pocket.
B: because people are uneducated about electricity, car audio, etc... and so are 95% of sales persons.
I WAS one of those 'car audio store' guys... and i can't count on both hands how much complete falsehood and bogus explanations I generally heard in a single morning from salespersons. It is ludicrous the rudimentary knowledge most otherwise excellent salespersons lack... and what they do have is usually 18th hand passed down from salesman to salesman since the beginning of time.
(alternately)
because "I have twin yellow tops" sounds much cooler than 'I have an OEM alt with a normal battery and a properly designed amplifier with the gains set properly.'
ok?
Enough of that....
On to the FACTS my dear mr Watson.
Dimming is:
1: a drop in system voltage (usually around 1/2 volt to 1 volt) due to demand being greater than supply - incandescent lights are VERY voltage sensitive, and even a 15% drop in illumination is very noticeable to the human eye.
2: Can occur only at the beginning of the note, which means the alternator is adequate but the regulator is slow, or can continue during the entire note (inadequately sized alternator)
3: there are two possible power supplies:
---key off = battery at ~12.8 v
---engine on = alternator at ~14.4
A battery will only begin to discharge ONCE SYSTEM VOLTAGE HAS FALLEN TO 12.8V, meaning you are already experiencing dimming. Until then the battery is a LOAD on the system.
Thus:
1+2+3 = a battery is NOT the answer for dimming... but it COULD be a cause.
A battery can still start a modern fuel injected vehicle and have practically no reserve, or be bad enough that it is enough of a load on the alternator to negatively affect the current available for other jobs.
usually these are teh ones that leave you stranded the first cold day of winter, the hottest day of summer, or the time you left the lights on to unload groceries for 10-15 minutes.
Alternators can also have a single bad rectifier on one phase, and LOOK like they are charging... but on a scope you can see that they just don't put out the current. like 2 moderate steps forward and one big step back.
Amplifiers can also simply be crap. To save a buck, many manufacturers now use inadequate onboard capacitance or marginal power supplies. these units will draw more wattage than they should need too, or 'hit' the charging system much harder upfront, which doesn;t give the regulator the milliseconds it needs to ramp up output. so you get the dim and comes back issue.
This doesnt mean run out and buy a capacitor... for one caps are ALWAYS discharging and are an additional load on the charging system. And they should be replaced every 2 years. ($$$) generally it takes around 5 farads to make any meaningful difference when it is outside the amp chassis, and even then you need to have the cap within 3 wiring inches of the amp power terminals.
So... lots more expense, no guarantee of meaningful results UNLESS the amp is poorly built. then you can buy a $300 bandaid for your $150 amp.
The real solution is
a: Get the smallest alternator that is adequate to your needs. if that means OEM then OEM
b: wire the system with adequately sized wiring. Remember Watts = Voltage x Amperage... voltage loss hurts, big time. lose voltage you pull even MORE amps, and that causes more voltage loss if the alt is marginal or in adequate, and you pull even more amps, ad nauseum; ad infinitum.
c: use low resistance couplings, ends, and fusing. Bolt down fusing best, but use ****, not AGU at worst. AGU is the absolute worst.
d: crimp fasteners beat the pants off set screw fasteners. Bare wires do corrode. use Dieelectric grease.
e: jacketed wire CORRODES TOO. If you are reusing wire for a decade... you'll see it. buy fresh wire and seal it up. For CCA wire, increase the wire to the next larger size for similar performance.
f: set the gains properly (see bcae1.com or other websites for directions) And buy an amp largeenough for your needs, and use an enclosure large enough for your needs. Two pioneer flat 12s with 350w each in an ultra small box are about the equivalent of ONE plain jane 12 in a normal box... with only 300w on it. And would lose handily to the same 12 in a ported box.
g; if it isn;t loud enough, remember that to double loudness you need double the power for twice the excursion. perhaps you need to step up to something larger. the gain can be used to REDUCE volume to balance the system... but should never be used to increase it.
Any questions?
whe you figure out WHY your lights are dimming, and what component is culpable, then you can figure out the PROPER solution. Don't throw bandaids and fairytale wishes at it.
If you want to try a second battery without the expense of rewiring for it///
use a set of jumper cables from one battery to the next.
you cna do that right at the car audio store.
however do NOT ever buy a stinger/dynabatt/odessey battery, you can get the same battery for a LOT less as a Hunter. (like 25-50% off).
You cna also monitor the voltage at the amp to determine if the 12.8v battery somehow magically raises the voltage at the amplifier. If the voltage is still dropping significantly, you still have the problem, even if you can't 'see' it in the day time/under the shop lights.
Just remember that two batteries wired in parallel sans isolator will pass small amounts of voltage back and forth when the engine is not on and will discharge each other and ruin each other.
I used to have twin Interstate type 26s for 1300 total CCA because my MGB only had a 30 amp alternator... and i had a 60+ amp system... I had to charge the batteries by driving sans radio 2/3rds of the time, and by using the charger at home.
that one DID run off the battery... so it never dimmed to the beat either, LOL. I never got around to installing a 100 amp Triumph alternator and an isolator to correct the problem.
Anyway, good luck to ya both.
http://www.youtube.com/watch?v=c5WC4qMxlTA
Max
Mile High
Denver
Good info! My truck barely dims and the stereo is plenty loud with the gains set low. I'm running electric fans, two amps, an eq, and one yellowtop with 1/0 wiring for the entire system on stock alternator. The stock electrical system can handle quite a bit in these trucks with a stereo that is tuned properly :imo:
briannorris
