BubZX
Senior Member
Waynesboro PA
[/IMG]Installed yellow fogs and depo headlights awaiting my ddm kits 35w & 55w 6k
[/IMG]
where did u get the depos from? I like how they look.
Rivieraracing
The first Arnott compressor had a defective exhaust solenoid, compressor worked when you jumped it. Guy I paid to pop this one in while I was at work didn't push the connector on properly. The weird thing is that the compressor didn't keep running despite the shocks not being full.
Btw-in case I forgot to mention it, thanks for helping me
No problem man, just keep a mental thought and an ear for the compressor running too much and/or air leaking especially when the warmer weather comes around! Things can slightly loosen up and might cause an air leak in the spring since it was all installed in the winter cold months! These compressors (OEM and Arnott rebuilds) can't handle excessive run time due to a loose fitting.
Yukongk
NY
Yea, thing is that I can't hear the compressor run when I'm driving, thinking of installing a light bulb near my dash and Tapping into one of the fuses?
Yuko04
"SquareBODluvr"
MN
Just washed it and now putting up on lift to wash undercarriage. .
Rivieraracing
Very true, the compressor is super quiet but every once in a while I'll idle the truck in the driveway for a bit and see if I hear the compressor work more than it should! Thought about the light idea as well but decided against it!
Red_Raider
Derby, Kansas
Ordered a cai kit from my "lovely" room somewhere in the desert. It still will be awhile before I'll be able to put it on, but at least it'll be there when I get home.
Tahoewhat
Ballin' on a Budget
TX
Thinking of HD Grille & cap?
-- Found out my rear main seal is leaking bad !! :Frustrated:
NCTyphoonKid
Trinity, NC
Washed the salt off of it and got to see some new 2015's at the dealer
Grimes
Awesome comparison pic. Really shows how beefy those new front ends are.
mharders
Just outside of Seattle
Picked up some new wheels and tires also installed my esky platinum cluster
Sent from my SAMSUNG-SM-N900A using Tapatalk
Tahoewhat
Ballin' on a Budget
TX
That would look great! All color matched of course.
Time for a built lq9!!
Yeah all matched of course, but uniquely done. Got to be different than the crowd.
And i wish. maybe just a little snail added to the 5.3. ha ha
Grimes
I'm really sorry to be asking this stupid question. Lol but what does NBS yukon mean ?
NBS is New Body Style. It varies in definition depending on what forum you're on, but here it is the era of body style on any GM SUV (Esky, Yukon, Tahoe, and their extended models). NBS is 2000-2006, NNBS is 2007-2014, and I guess NNNBS is the new 2015s.
---------- Post added at 11:07 AM ---------- Previous post was at 11:05 AM ----------
Fix the dent homes!
Looks good though. I had to struggle deciding for an LED strip for parking/turning/side marker or stock with LEDs. Went stock for simplicity, no regrets though. The strip is just too tall in my opinion. The new Sierra works the thin strip well.
Mountain Rambler
