Hello everyone.
First I'd just like to say I hope I joined the right website. I know it says GMC Tahoe/Yukon/Escalade. I'm hoping the 2005 Suburban can fit in this catagory since it's pretty much the same as the Tahoe.
The SUV itself is the 2005 Suburban 1500 LS 4dr 5.3L V8 with Bose system and Navigation system.
I'm hoping to just find out everything I'll need to know (And purchase) to completely install a new system, as well as to information on the system itself.
After reading some posts and googling, this is what I've thought so far.
Stereo: Pioneer DEH-X6600BT
Sub Woofer: Kicker CompVR 07CVR154 15-Inch 4-Ohm DVC Subwoofer (Or should I just go with 1 15"?)
Box: R/T 300 Enclosure Series 328-15 Kicker
Amp: Unsure, still trying to figure it out.
My questions,
I'm not sure if I understand the ohm voice coils. The Kicker has 4 ohm at 500 Watts, so I think that means with two Kicker 15's I want an amp that does 1000 Watts at 1 ohm?
What sort of installation kits/wire harness will I need to get in order to install the stereo?
What sort of wire will need to be used to run from the battery to the Amp?
I'm completely open to suggestions on what you think would be the best route to go, thanks!
---------- Post added at 08:36 PM ---------- Previous post was at 08:15 PM ----------
Also forgot to add, I was rummaging through Amazon at their packages and these two have the subs and amps together, would that be a better route? I'm not really sure what the difference between them is.
2) KICKER C154 Comp 15" 1000 Watt 2 Ohm Car Subwoofers Combo +Amplifier+Amp Kit
2) Kicker C15D4 15" 1200W Subwoofers + Boss AR2500M 2500W Amplifier + Amp Kit
My questions,
